Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-06-2012, 10:38 PM
thundersnow70's Avatar
thundersnow70 thundersnow70 is offline
1960 Ford F-250
My Garage
thundersnow70 is starting off with a positive reputation.
easy orphan fridge blinker fix
so the other day i noticed that the blinkers needed some work so we dug in and noticed the springs behind the buttons were wasted. went to the parts store and got the wrong replacement parts. back to the parts store for the right ones and began the resto.Click the image to open in full size.
then the clean-up and primer Click the image to open in full size.
some gloss white paint Click the image to open in full size.
cleaned up the brass sockets Click the image to open in full size.
after the cleanup the brass sockets were a little loose in the housing so we pressed them back in with a extra ground wire.Click the image to open in full size.back together and ready for the new insides and reinstallClick the image to open in full size.napa part number is LS6469 and slides right into the stock socket location. wired back up and washed the inside of the blinker lenses. installed amber bulbs just for fun and away we goClick the image to open in full size.
__________________
52 F2 & F3 Merryman Herringbone
60 F250 4x4
63 F250 4x4 Flareside
Mark
I might be in a cage at the zoo, but I'm still king of the jungle!
  #2 (permalink)
Old 06-07-2012, 09:59 AM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Garage is empty, add now
theodore/teddy is gaining momentum as a positive member of FTE.
Thundersnow, thats a good idea on the ground when did you run it to? A mounting screw or to the frame, or ?
__________________
1959 F250 4x4
Wally
  #3 (permalink)
Old 06-07-2012, 06:58 PM
1960 Ford F-250
My Garage
just ran it up with the original wiring and used a self-tapping screw to mount it on the front part of the inner fender. looking back on it i could have just used the wire to tighten up the socket in the housing and then it would have grounded as it was designed. figure an extra ground cant hurt. its a wonder i never got pulled over. only had one front running light and one front blinker. on different sides. also had one low beam and one high beam out. now that its all fixed i will probably get pulled over. now i should be able to see what im about to hit................at night anyway!
__________________
60 F250 4x4
Mark
  #4 (permalink)
Old 03-17-2013, 01:34 PM
leewiffen leewiffen is offline
leewiffen is starting off with a positive reputation.
How do these lights come out? Do they have a nut up under the fender? I have the same problem...thanks for the link
  #5 (permalink)
Old 03-17-2013, 11:09 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Very Nice job there! I am inspired to do mine. A+ on that assignment.
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
