Front brakes AND wheel bearings?
The only trouble I had taking the bearing assembly off the truck was getting the rotor off the hub. It was stuck real bad. I ended up having to take the hub bearing assembly off tge truck with the rotor still stuck too it. I then used a sledge hammer with a piece of wood to hammer the rotor off the bearing assembly. Thinking back, I prolly should have uaed heat.
Also could be the ball joints.
There's a product you can buy at the auto parts store, caliper slide pin grease. It's very sticky high temp grease. A couple tubes is less than $10 and would be good to have before you start. Also, smear anti seize compound on the rear surface of the brake rotor before re-installing. Should help with the next time. Obviously, the anti seize goes around the lug nut studs, not the braking surface.
super 6.8
09-18-2016 11:59 AM
Pigman54
26
11-24-2013 08:22 PM
