turn signal/brake lights
Help
Hey guys I'm new at this I've worked on old Ford cars and trucks for a few years and always figured out when something went wrong but I just got this 1978 f150 4x4 and I cannot get my break lights and turn signals working I've already changed the break switch and the two flashers switches for the blinkers and flashers and I've even pulled out my whole wiring harness from the back to the front of the truck. I followed my brake switch wires which r two red wire but one has a black line on one of the wires which I'm sure is a negative but followed it and it goes right to the dimmer switch I feel dumb for asking but can someone please help me?
Welcome to the forums.
You need to start with the correct year forum:
1973 - 1979 F-100 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
But, they all are pretty much wired the same basic way.
Not sure why the brake switch is wired to the dimmer switch for the headlights? That is just wrong. The dimmer switch should have the main power wire from the headlight switch going to it so it can switch from Lo beam to Hi beam. Nothing else. The brake light switch should actually go through the turn signal switch to allow the rear lights to blink when activated.
You removed all the wiring? Was the original harness cut up/destroyed? Sounds like it if things aren't working right. You might want to post in the other forum, maybe someone has a wiring diagram they can show you.
Bigdog8333
07-29-2019 03:59 PM
allwthrrider
06-28-2011 06:28 PM
stewards68
38
03-27-2007 10:15 PM
kermmydog
11-12-2006 11:34 PM
