Brake lights staying on
I have a 69' F100 and I am having an issue with the brake lights staying on. I had a blown fuse so I replaced it and now when I turn the truck off the brake lights stay on. I have to pump the brake in order for the lights to go off. Does anybody know why it would do this. They work fine and dandy except for we I turn off the truck.
The brake light switch screws into the bracket on the pedal. If it comes loose, it will then not push far enough to open the contact and shut the lights off. Take a look and you'll see what I mean. It's a grey plastic push button with two wires.
Mine was like that originally. Someone previous had put a small hose clamp on it to hold it steady(threads are stripped on switch). 25 yrs and still going strong.
Smoke, either your switch is stuck or unplugged? How's your turnsignals? Ok, then it won't be a turnsignal switch issue.
Turn signals ok!!!
The 4 speed switch location varies on the shift tower, as it depends on whether the 4 speed is a Warner T-18 or a New Process 435.
Note: 1967's use a different stop lamp switch and brake pedal mounting setup than 1968/72's.
I'm having this same issue right now, when i got the truck about a week ago they told me they stay on and they keep a metal bar in the car to push against the firewall and lift the brake pedal up. I have yet to even look at it because im cleaning out the garage first but thats some good info about the switch, can I tighten the hinge the brake is on to lift it higher? Or does it just kinda sag like that usually?
I replaced all the fuses and did a OPS check, all are operational. I just replaced brake switch after checking if there's power, one side of the connector is hot and the other isn't, this should be the norm. Went ahead and connected the switch and there's still no brake lights. The only thing is I replaced the steering collar because the shifter handle retaining pin section was wallowed out, which created allot of play and fixed the horn. Could there be an disconnection from making this repair? What's the answer guys?
fixed it with a rubber bumper
My brake wasn't making enough contact with the switch, so I just added a small rubber bumper, the types you find on the bottoms of laptops. Worked perfect!
