EFI AOD to carbed 351w
Transmission spotters guides:
Ford Transmission Spotter's Guide .: Articles
https://www.ford-trucks.com/user_gal...id=169485&.jpg=
Note the AOD is going to look the same as the AODE and 4R70W, but the difference in the shifters as explained in the first link, as well as the bundle of wires as per the prior post should tell the tale.
AFAIK if it had a TV cable, it's an AOD--no reference to a TV cable on the other transmissions.
The 351W EFI, I thought that had a C6 in 88. IIRC they never put an AOD behind a 351 after the early 80's Crown Vic. 89 the E4OD came out. Does the trans have a vacuum modulator coming out of the rear? If it is an AOD, it would most likely be behind a 302. Look to see where the EGR pipe goes, into the intake it is a 302, into the pass manifiold it is a 351W
mikeinmilton
06-10-2015 03:10 PM
