429 in F700 loses power at full throttle
1995 F700 429 V-8. Truck starts, idles and runs well at all speeds, but when running at full throttle up a long steep grade, the engine will lose power fairly suddenly almost as if it is running out of gas. After the speed drops down to around 20 mph the engine seems to gain power again and it will accelerate reasonably well. Would this likely be a fuel or ignition problem? Assuming the fuel filter may be clogged and need replaced, where is it located? Thanks, Tom
Dual tanks? If so, try switching tanks while on the grade. I had the same problem and when switching tanks felt like a turbo would kick in.....was the fuel pump in one of the tanks. The fuel filter should be in front of the tank, mounted on the outside frame rail, at least that's where mine is on a '91. You'll need the special fuel line tool to get it off.
samstigg
11-23-2011 06:15 PM
Slackdawg05
03-09-2010 06:42 AM
85vanman
06-08-2002 06:52 PM
