1993 7.3 IDI Oil Usage Problem
Old 05-17-2012, 12:35 PM
kjgibson2's Avatar
kjgibson2
kjgibson2 is offline
ok cool thanks, now i just need to find a starter lol
Old 05-17-2012, 12:45 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
How dose the CDR come out of the 6.9L? Dose it just pull out or is it bolted in.
Chet
Old 05-17-2012, 12:52 PM
kjgibson2's Avatar
kjgibson2
it looks to me like it pulls out of the intake gasket, i think there is a grommet that kinda screws in and the cdr just pops in i think, but i'm not certain
Old 05-17-2012, 01:00 PM
Bonanza35's Avatar
Bonanza35
Thanks I never had mine out. I'm going to change injection pump, glow plugs and injectors so I guess I need to look at this thing. Just don't want to break it trying to pull it out.
Chet
Old 05-17-2012, 01:09 PM
kjgibson2's Avatar
kjgibson2
i'm not 100 percent certain so be careful, if your doing all that you may wanna look into some gaskets while its apart, easier when that stuff is out of the way then doing it in 10000 miles and taking it all apart again
Old 05-17-2012, 01:16 PM
kjgibson2's Avatar
kjgibson2
ok, from what i've found it just pushes down in the grommet in the valley pan and then bolts to the intake
Old 05-17-2012, 01:34 PM
Bonanza35's Avatar
Bonanza35
Kjgibson2, thank you. I'll have to look for that bolt before yanking on it. What gaskets are you talking about? I am replacing the return lines and all.
Chet
Old 05-17-2012, 01:50 PM
kjgibson2's Avatar
kjgibson2
you don't have to, but you may find it beneficial to pull the heads and intake and replace the head gaskets, intake gasket, and valve cover gaskets while its out, and the glowplugs as well. if your not running the motorcraft glowplugs you will definitely want to try to change them while the pump and injectors are out, and they are notorious for breaking off in the head which means you'll have to pull the head to fish out the pieces, if your tuning up the injection system its going to be alot easier to tune everything up at once instead of trying to do it later on. just my .02
Old 05-17-2012, 02:06 PM
eatont9999's Avatar
eatont9999
eatont9999 is offline
The CDR valve is held on by two bolts that attach to the back of the intake manifold. Remove the two bolts and lift up on the CDR while twisting. Soak it in gasoline for a little while to clean it out.
Don't replace any intake or head gaskets unless you have the engine out of the truck and want to do it for PM or you are having issues with them.
Old 05-17-2012, 02:30 PM
Bonanza35's Avatar
Bonanza35
No, the motor is still in the Van so I won't be doing head gaskets and all. Thanks on the CDR, I didn't know much about it. Truck was getting harder and harder to start, and lose on power on the slightest grade. This van set alot over the years, and other then what I said about it, its good. Dose use oil, and the front seal on the trans leaks, and the gauges don't register for fuel right. I need to repair this for work. I've had cancer the last 5 years so I've been out of it, but am getting better now. Thanks you all for your help.
God bless,
Chet
Old 05-18-2012, 12:11 PM
eatont9999's Avatar
eatont9999
God bless,
Chet
Van? Oh, I pity you. Those are real fun to work on. At least you can access the CDR valve real easy. Usually low power or performance means the injection system is ready to be replaced.
Glad to hear you got over the cancer.
Old 05-18-2012, 02:14 PM
kjgibson2's Avatar
kjgibson2
Definitely good to hear your over it Chet
  #28
Old 05-18-2012, 11:33 PM
Bonanza35's Avatar
Bonanza35
Takes guys. Its one step at a time. God bless,
Chet
  #29
Old 05-19-2012, 12:26 AM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
If anything.. oil consumption would add power. 1. Its extra fuel 2. i forget the correct term but oil has more bang than diesel, when i was running 40/60 wmo/#2 my mileage was slightly up.
  #30
Old 05-19-2012, 08:05 AM
kjgibson2's Avatar
kjgibson2
Yea but oil is more expensive, at least new engine oil is anyways
78sharpshooter
01-24-2008 02:45 PM
markusselanne
01-16-2008 08:07 AM
Oaktree
03-21-2006 05:18 PM
KJKozak2
05-23-2005 08:02 AM
ole_blue
01-17-2002 09:31 PM
Quick Reply: 1993 7.3 IDI Oil Usage Problem
