Power steering bracket
Does anybody know if ford used different sized p/s brackets?
I tried today to take out the spacer that's between the upper bolt on the water pump that the p/s bracket bolts to.
So I took the spacer out, only to find out that the holes in the water pump don't line up with the p/s bracket bolt holes.
I can't get the lower hole to line up with the upper bolt in place.
I found a a/c comp. mount that I'm trying to mount to the block, and with that in place, the bracket for the p/s is pushed to far away from the motor, causing the belt alignment to be way off.
My truck is a 79 4x4 with a 400 out of a 79 Lin cont., so I don't know if I have a mixture of parts or what.
So did ford make different style p/s brackets for a/c and non a/c? And would there be any difference between the Lincoln and a ford bracket?
Thanks.
Thanks.
Found this on ebay.
75-81 FORD 351M 400 TRUCK POWER STEERING BRACKET | eBay
Does anybody have this particular bracket on their 400 with A/C?
on
Here's one complete:
Ford Power steering pump bracket 351M 400 351w Vbelt style 78-86 | eBay
And one cheaper:
Ford 351M 400 Power Steering Bracket | eBay
And one cheaper:
And one cheaper:
And one cheaper:
The other link i posted was a different bracket, and i was wondering if that was the one i needed?
This is the mess I'm facing.
[IMG][/IMG]
on
I don't have a 400 but they all use spacers in one form or another. Different spacers for ac brackets or without. Use washers to align the belts then measure and cut spacers to fit.
I think all three ebay brackets just now posted are the same; 351/400 and are the same as the one you have.
The first link i posted has a bracket that is mounted different than mine.
If you look at where the bracket would bolt to the head, it has several holes as compared to mine that has one, and also it looks shorter in the area to, maybe so the A/C bracket could fit behind it?
And the bracket i have, the water pump holes don't line up with the holes in the bracket, so i have to have the wrong bracket or something.
