Starts, runs, dies after 20 min
Old 05-05-2012, 01:58 PM
kf1128's Avatar
kf1128
kf1128 is offline
Have a 1960 f250 with a 223. Truck will start and run fine for 20-30 min and then it dies. Will eventually restart, sometimes not till the following day. Also seems to getting pretty hot. Cleaned fuel filter and put on rebuilt carb. Any thoughts would be appreciated.
Old 05-05-2012, 02:46 PM
AndyZell's Avatar
AndyZell
AndyZell is offline
check the fuel line that runs in the tank. my 60 f100 did that for a while till i cleaned that line. and also pressurize the tank periodically by blowing into the filler spout to get a good stream of fuel getting in the lines. and if its getting hot you might have some air in the cooling system i would try burping it to see if that helps.
Old 05-05-2012, 03:11 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
First thing I'd do is see whether it lost spark or fuel when it died. There are some pretty simple diagnostic steps we can walk you through to avoid the old "let's throw new parts at until it's fixed" method.
Old 05-05-2012, 03:53 PM
spurredon's Avatar
spurredon
spurredon is offline
The coil could be getting hot and opening up but I would tend to lean toward feul line/fuel tank/filter stuff.
As was mentioned, tell us what it is doing or not doing when it quits. They are a fairly simple engine to work thru.
Old 05-05-2012, 03:56 PM
AndyZell's Avatar
AndyZell
AndyZell is offline
i have a question. when it dies is there fuel in the filter?
Old 05-05-2012, 05:25 PM
kf1128's Avatar
kf1128
kf1128 is offline
Thanks for all the replies. There is fuel in the filter when it dies. Just checked and there is currently no spark, started and ran for 20 min earlier today.
Old 05-05-2012, 06:02 PM
MARC's Avatar
MARC
MARC is offline
sounds like hot coil, 10.00 part at local auto parts store
Old 05-05-2012, 08:01 PM
AndyZell's Avatar
AndyZell
AndyZell is offline
yup most likely the coil
Old 05-05-2012, 11:01 PM
jacks61ford's Avatar
jacks61ford
jacks61ford is offline
I agree with
Old 05-06-2012, 05:15 AM
spurredon's Avatar
spurredon
Could also be some other connection that is corroded and vibrates apart while it is running. Later after it sits, it can touch just enough to run again. Where the harness plugs into the firewall is a perfect place for something like that to occur. I did mention the coil earlier but they often get the blame first. Then you have to spend the time to find the real problem.
Old 05-06-2012, 10:28 AM
willowbilly3
If you don't own a test light, go buy one. Start checking for voltage at the coil + with the key on. If there isn't juice there then backtrack to the switch. If there is juice at the coil + and you have no spark, check for juice right at the points, they will have to be open for it to light up. Also on the wire to the points, the coil -, it should blink the light if you check while the engine is cranking.
I'd like to find those $10 parts store coils, last one I bought was more like $40.
Old 05-06-2012, 10:38 AM
MARC's Avatar
MARC
MARC is offline
ok..ok..ok, I admit it has been years since I had to buy a coil... now 25-30 bucks
Old 05-06-2012, 07:32 PM
spurredon's Avatar
spurredon
Give China time to get the price down, they already have the quality down to $10!
Old 05-06-2012, 09:13 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Sometimes the truth is funny even when it hurts!
RamdyZavage
08-23-2017 12:49 PM
SVTME
09-05-2010 03:03 AM
whimsy
01-25-2008 08:24 AM
rogmale
07-22-2006 11:39 PM
gearshift101
12-11-2003 06:48 AM
Quick Reply: Starts, runs, dies after 20 min
