WVO tank
Old 05-04-2012, 10:28 AM
rocketman2440's Avatar
rocketman2440
rocketman2440 is offline
WVO tank
Do any of you guys see any reason why I wouldn't be able to use the original tank on my truck as the WVO tank, and use a smaller (5 gal.) plastic one for my diesel start up?
Old 05-04-2012, 02:49 PM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
The wvo will either eat the liner out of your factory tank, or it will react with the steel. Go with aluminum.
Old 05-04-2012, 05:18 PM
rocketman2440
I have a 99 with the plastic tank
Old 05-04-2012, 06:15 PM
444dieselrod
You should be good to go then with the plastic tank.
The front tank on mine is plastic, but I don't drive long enough on my way to work, figured a smaller tank would heat faster, so I had to go that route.
Old 05-04-2012, 09:44 PM
rocketman2440
Cool, now time to fab up some mounts for the startup tank. Well it stays hot enough down here in the summer for me not to worry to much about a heated tank for a few months.
Thanks for the replies
Old 05-07-2012, 09:47 PM
SkySkiJason's Avatar
SkySkiJason
SkySkiJason is offline
Received 1,897 Likes on 1,145 Posts
I know a few people running WVO in stock PSD tanks (plastic). Use a Hot Fox or similar heated fuel pick-up and no problems with the cold in your area. Ya don't ever want to heat 'the whole tank' anyway, its a waste of heat and shortens the life of the oil (expedites polymerization).
I also recommend TIH fuel lines and either a loop of TIH after fuel press regulator or a FPHE for heat. Shoot for at least 150* before the engine.
You aren't gonna share fuel pump or filter with diesel right?
Old 05-07-2012, 10:05 PM
rocketman2440
Thanks Jason, I actually just got in my pump in from WVO Designs
and will filter it through a Vormax that I picked up used for cheap.
Hopefully I will be able to get everything mounted and plumbed in the next few weeks.
dmyboat
04-10-2015 11:54 PM
montey2005
6.7L Power Stroke Diesel
12-02-2012 08:58 PM
rocketman2440
Bio-diesel, Propane & Alternative Diesel Engine Fuels
02-16-2012 08:32 AM
6.9OriginalDiesel
06-15-2007 08:44 AM
Quick Reply: WVO tank
