86 302 f150 i need help with timing
Old 05-03-2012, 03:13 PM
Anthony Light's Avatar
Anthony Light
Anthony Light is offline
i need help timing my 1986 f150 it has the 302 and i get the #1 piston to tdc and the rotter button to the #1 plug wire but the crank timing mark is about 180 out.. the truck will start and idle ok but as soon as it gets worm it wants to die. how do i get the crank make rite?
Old 05-03-2012, 03:50 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Welcome to FTE, Anothony.
You need to be TDC on the *compression* stroke, not the exhaust.
Old 05-03-2012, 04:00 PM
Anthony Light
i have done it about 20 times and i know for sure that the last five times have been
Old 05-03-2012, 08:10 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
I'm thinking you must be correct that it is on the compression stroke or the engine would never run. Given that, the harmonic balancer must have slipped, which isn't too unusual. Having said that, is it exactly 180 out? If so I can't believe that it has slipped exactly 180. But, a slipped balancer is all it can be.
You can either replace the balancer, which is what you should do, or mark the true TDC and then something like 10 BTDC using measurements. But, the balancer is highly likely to slip more, and can even come off the hub so you really should replace it.
can0fspam
18
04-16-2018 07:10 PM
Drac
03-17-2008 11:04 PM
Keith5
02-06-2005 07:50 PM
CJ7
11-25-2003 05:42 PM
swall
12-02-2002 09:18 PM
Quick Reply: 86 302 f150 i need help with timing
