What causes cracked heads?
Ok I was hoping it was only bad gaskets, but after mechanic got the heads off, both sides were definately cracked.. I have searched and found lots on blown gaskets, stretched bolts etc. Even read where others have cracked heads..But what is the reason? Engine getting hot? Just looking to make sure I fix it right so I don't have this happen again...
Doing new heads (obviously) ARP studs, dummy plugs, stand pipes, turbo cleaning, new Y pipe and going to delete the egr. cooler. Checking HPOP screen but it was replaced last summer with new oil cooler...
Engine ran great, and as long as boost was below 25# I never lost any coolant at all even after several thousand miles...But pulling a light 2 place enclosed snow mobile trailer up a 18 mile grade at 29 # of boost (highest temps. 214*coolant; 228*oil I would lose a whole gallon of coolant out the degas bottle, that is the reason for the tear down. Was thinking stretching head bolts or head gasket...
Any information you can give me is greatly appreciated and I can go over and compare to my heads..I havn't looked at the heads yet but was thinking of going over tonight or tommorow and look at them..
I believe one of the mechanics use to work for a Ford dealership and specializes in the 6.0...The guy loves working on these engines...There current shop is too low of a ceiling for a floor hoist so they pull the motor out the front...
When I baught the truck there was a mysterious 3 postion mini toggle switch with wire dead ending in the engine bay...I think the previous owner had a Bully Dog tuner. So that may be the source of my problems..I have had haunting water issues since day 1 of ownership...With gauges I got it narrowed down to continous high boost..
But I should be better than new after this repair, I will have replaced dummy plugs, stand pipes, going to go ahead and do a Sinister egr cooler delete, oil cooler replaced, hpop screen, FICM rebuilt by Ed with Atlas 40 installed, water filter installed,blue spring installed, new water pump, front cover,thermostat, idler pulleys and tensioners, both alts new,FASS clutch new,oh yeah and ARP studs..... I have a SCT unit and will get custom tunes from Matt. ( mercy that is a lot money spent) Will check on the head cracks before replacing them, Thanks for the advice Cheezit..
Really I am glad for the advice and information on this site, as I am more aware of what to monitor and watch for. Guys like you, Cheezit, Bismic, and Tex 25250, ( is that the right sig.?) Mark Kovalsky, have helped me a lot...
well, hydraulic lock will break most things.... and if you got it good and
hot and blew the head gaskets and got enough water into the combustion
chambers to fill them, or close to filling them, then you get the thing best
described as tinkey, tinkey, bang. water doesn't compress well.
cast iron is pretty stable and doesn't move around like aluminum does,
so it's a good choice for heads, but it doesn't flex worth a damn. it just
cracks. i've been told that the 6.0 heads crack a lot around the valve
seats, so rather than do a piecemeal repair, i just that the valve seats
machined ad inserts put in.
Also do you have a cracked degas Bottle?
Went and looked at the heads tonight and they are cracked from the glowplug hole clear thru the valve seat to the stem hole..
So the new heads are now on and arp studs installed. But the heads cost me 1,463.00 ea.....Ouch..... I looked to see if they had gold plating but didn't find any.....lol...
Mech 1990
09-30-2019 09:55 PM
