Hi newb with question
Old 04-30-2012, 05:22 PM
bk53's Avatar
bk53
bk53 is offline
Hi I've been lurking around for a few months. I drive a 53 f100 with a 239 and fordomatic. load-o-matic dizzy h94 etc. I've got an issue with wear on the slip yoke. I think the part I need is a b5c 4841-a First I'm not sure of the pn second, i've called all over and searched and apparently this is a pretty rare part. I could use a lead if anyone has one. Third can I have this machined or chromed or anything to bring it back? can I mabbe sand it down and use an oversized seal? some trick to put the worn spot somewhere other than right at the seal?
appreciate any help or ideas you can share.
Regards,
Bill
Rowlett Tx
Old 04-30-2012, 06:20 PM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
If it's just worn where the seal rides then have your locale bearing shop get you a speedi sleeve/seal kit . that should cure a leak problem 9 times out of 10 .
Old 04-30-2012, 06:24 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Try to find a good drive line shop or machine shop near you.....that is how I found a new yoke for my 3 speed. Do you know the spline count and u joint type?
You may also be able to put a speedy sleeve on for the seal to ride on...
And welcome to FTE!
Old 04-30-2012, 06:34 PM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
Sorry I forgot to welcome you to the group . These guys are a great source of helpful advice and knowledge .
Old 04-30-2012, 06:38 PM
bk53's Avatar
bk53
bk53 is offline
speedy sleeve! someone has thought of dang near everything haven't they? Yeah it a 16 spline and I just threw out the u joint box. Thanks for the welcome.
Bill
Old 04-30-2012, 11:33 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Bill,
Welcome Aboard! Quite a few of us down around Austin - Put some pics
up when you get a chance. Would love to see your truck. My truck is up in Waco - My son at Baylor borrowed it for a weekend about 8 weeks ago...
Ben in Austin
1950 F1
Old 04-30-2012, 11:51 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,469 Likes on 1,408 Posts
Hi Bill, welcome to the forum! My old Ford parts catalog shows 53-54 F-100 Fordomatic slip yoke being part number TAAA 4841 B. 1955 used the B5C 4841 B. That's not to say the earlier number wasn't superceded by the later number, because it likely was. It's also very likely been superceded since then, as well. Ford is famous for changing numbers on parts. It at least gives you another option to look for. That same yoke was also used with overdrive manual transmissions, too. But the speedy-sleeve option will probably be your easiest, cheapest, and fastest solution.
Jay_ford476
1997 - 2003 F150
05-25-2013 07:56 PM
Greenheadkiller
1997 - 2003 F150
06-23-2012 07:49 PM
Race4Fun82
09-19-2006 09:22 AM
Skagit
12-23-2003 06:30 PM
Derwydi
04-21-2000 05:12 AM
Quick Reply: Hi newb with question
