Wheel Spacer?
Wheel Spacer?
So i assume the point of these is so the tires stick out further? Are they a good idea or a bad one? i like the look of the tires coming out of the wells which mine do but id like a little more. So what the positive and negatives of these?
Also is there some that anyone would recomend?
1974 F250 4X4 Std Cab 8' Bed
While they do make the tire stick out farther, I think the primary reason for their existence is to use wheels with different mounting hole patterns, like to convert 8x6.5 to 8x170. They would also function to move a wide tire out to clear when making tight turns.
IMO, I dont like them as they move your weight bearing away from the hub. I'd prefer a wheel with less backset.
Also, I believe our trucks are hub-centric, meaning the load is transferred to the wheels through the hubs, and the adapters are lug-centric
Wheel Spacer Adapter 8 Lug 6.5" To 8 Lug 6.5" (Pair) 9/16" Stud: Offroad Overstock
And i thought our dents were lug centric?
OOoooooo nice! Do you have or see how they could cause a problem? And is there a problem with running them in the rear? I have 35"s as well and the front rub but id like the front and rear to both stick outa the wells the same distance...
Also where di you get yours and how much?
i got mine from a local shop here, called Pick-up Parts in Mission Viejo SoCal. These will add stress on the bearings just like running wide rims with a deep offset. Use lock tite and torque to - I think 90 lbs., double check. These are a temp till' I get wider beams and/ or custom radius arms. People will give your their opinions on these, do some research and you'll see that people use them with success, even desert race teams. The rears should be no prob.
hotrodjohn71
07-25-2015 07:17 PM
Big Red 78
05-07-2010 09:16 AM
