Fuel level sender
Originally Posted by lavatan
The ID engineering number I could find is E5TF-EA
I wasn't able to find one, either, but I paid closer attention to what he (lava) said:
Post #1: "I finally got around to dropping the rear tank on my truck."
That's odd, rear tank there, yet we're looking for a side tank.
(sigh) A side tank could be either a mid-ship or aft axle tank, kiddo.
Post #9: "I'm assuming both sending units will be the same for both tanks...."
Incorrect.
Seems to me this is a Frankentruck.... I googled the ID numbers he posted, found *one* relevant hit:
1985 Ford F350 - 18879335 8 CYL. 5.8L (351 C.I.D.)-W-GAS -midship:
9275 Sender Assy - Fuel Tank (NOT AVAILABLE wanna bet? ) **TZ-9275-C Use w/19 gal. aft axle tank - incl. (1) E1VZ 9417-B gasket - one tube -
Stamped E5TF-EA gas exc. 460-unleaded fuel, 1985/1986 Ford 350 Series
Incorrect.
Applications: 1985/86 F150/350 w/19 gallon midship tank / All 6 & 8 cylinders except 460 non EFI gas engines / Use with unleaded fuel.
How many would'ja like? There are 612 available NOS ~ SIX HUNDRED & TWELVE!
And btw: How many Ford trucks have you ever seen with a fuel tank at the rear, below the tailgate? Dunno of any, except for the unthinking peeps that install Mustang tanks in this location.
Assume thay are unaware of the exploding Pinto fuel tank FIASCO, or don't give a hoot.
I don't know how this could have been a Frankentruck. The guy I bought it from was not ambitious enough to replace anything on this truck and lazy enough to really screw up the wiring. He put a carpet remnant in place of a back windshield because he was too cheap to replace it. With that being said, the aft-axle tank is the sending unit I need.
This is a Crew cab F-350 long box. It never had an electric fuel pump that I could see. The fuel selector valve still works which is why I'm running on just the front tank (mid-ship) for now. Maybe the guy that owned the truck before the guy I bought it from did put a second tank in, but there should still be a replacement for the sending unit.
Another reason I don't think this is cobbled together is the fillers are in the correct place on the side.
ND, the part number E5TZ-9275-G that you posted previously; what is included with that? For the places that I've looked they have them marked at $180 up (that includes partsguyed.com). That seems awfully expensive for just the sending unit.
E5TF-EA = Ford part number: E5TZ-9275-G = Mid-ship Fuel Tank Sending Unit-includes E1VZ-9417-A mounting gasket.
There are 24 Ford parts depot centers (PDC) in the US, none have this sender in stock. Usually on a vehicle this old, this means the part is cancelled, obsolete, not serviced, not replaced.
But who knows for sure since the prices come up on the following websites. Usually when a part is obsoleted, there are two possible messages: This part is discontinued / No part number found.
MSRP: $245.05 / Dealer net cost: $147.03
FTE sponsor tousleyfordparts.com price: $161.63 (Tousley: White Bear Lake MN).
FTE sponsor partsguyed.com price: $176.44 (partsguyed: Horizon Ford Truck Center in Seattle WA).
Neither Tousley or Ed have this part in stock. Since there is no PDC status for it, I doubt it can be ordered from FoMoCo.
No one in IA has any.
VINTAGE PARTS in Beaver Dam WI has 274 = 877-846-8243 / I doubt you can buy it at a discount.
There are myriad other sources that have this part, so if you more, ask. It you want all of them, you'll have to phone me, cuz I'm not typing them all here.
I took this part out of the aft-axle tank. Unfortunately I can't really take both tanks off as I still need the truck to run right now. My Sebring is down right now and my wife uses the van to get to her work.
Anywho, to answer your question, that is the sender that came out of the aft-tank.
So, it wasn't in the aft axle tank originally. A previous owner either couldn't find the correct sender, or didn't wanna pay the outrageous MSRP, and found that this one sorta matched the original.
If Archion can find you the correct sending unit, that's just ducky. But, there nothing else that I can do. You have the wrong sender, so its ID number is worthless for finding the correct sender.
Sorry.
But, it's still not the correct part.
