79 460 with a 4spd manual flywheel ??
390 wouldn't make sense to me...that's a completely different engine series (FE)...but stranger things have been true I guess.
I'm going to try and get someone who has some experience in this very issue to chime in. It seems to me, if I remember correctly, that there is an issue with how far the pilot bearing sits in the crank on the 351/400M vs the 460.
I guess I'm a little confused with the original question.
You're swapping the 351M for a 460 and wondering if you can use the 351M flywheel and clutch, legitimate question.
You also state that you were told you "need" a 390 flywheel. I was unaware the where compatible but if you're going to go get a new flywheel, why not get one for a 460?
The way I see it, you have 3 optoins:
1) use existing 351M flywheel, if it's compatible
2) get one for a 429/460
3) get one for a 390 (but why would you do that?)
i have a 78 460 that had a 390 flywheel. its ok if you only plan to pull start your truck every time you wanna drive it which i highly doubt. ive put a new flywheel on once and have been through two brand new starters. it eats the teeth off every time. dont use a 390 flywheel they wont match up. you cant put a 390 starter on it.
I know for a fact you cannot use a 80s or 90 stock 460 flywheel with the 351M/400 bellhousing. I tried to do it and the flywheel is too thick and the geometry of the throwout arm is off and it binds up. Best advise is bite the bullet and pay the $600 for the L&L flywheel and clutch set. Use a pilot bearing for a 302 motor(it installs in the smaller of the 2 holes in the back of crank). This combo works. The 390 flywheel, I don't know about. I have heard this as well, but haven't tried it.
rathighboy
02-20-2008 09:38 PM
crazyredneckanyhow
08-05-2007 12:44 PM
boone444
10-13-2002 06:36 PM
sledhead1
04-10-2001 12:53 PM
