C6 Stopped Working
Old 04-27-2012, 04:47 PM
rbaruffi's Avatar
rbaruffi
rbaruffi is offline
C6 Stopped Working
I have a C6 with a Hughes 2500 Stall Converter behind a 390 FE. They are in 1974 F100. Both have about 300 miles on them since the rebuild. Up until 3 days ago the C6 performed perfectly after it got warmed up. It has an external cooler but no kick own rod and 14 quarts of fluid. As I was getting up to speed (30-40 MPH) it suddenly "went into permanent neutral". No banging, grinding, or any noise. Just as it I put it in neutral. Back home I checked the linkage and for fluid in the modulator vacuum line...all OK. Does anyone have any idea what happened ? I do have Park and Neutral but no forward gears or reverse. I just noticed a slight leak from behind the inspection plate that was not there before. Please Help
Old 04-28-2012, 01:09 PM
hollenjoe's Avatar
hollenjoe
hollenjoe is offline
im no tranny expert but sounds like your pump went out...
Old 04-28-2012, 01:55 PM
critterf1's Avatar
critterf1
critterf1 is offline
Probably a pump. Does it make any noise?
Old 04-28-2012, 09:38 PM
stuart1's Avatar
stuart1
stuart1 is offline
Remove a cooler line and fire it up. If there is good flow the pump is working.
Old 04-29-2012, 04:26 AM
rbaruffi's Avatar
rbaruffi
rbaruffi is offline
No Sir,
It made no noise at all. It just seemed to go into neutral.
Old 04-30-2012, 09:10 AM
hollenjoe's Avatar
hollenjoe
I would try what stuart1 said and move from there..
IDIDieselJohn
17
06-18-2012 04:39 PM
76250_4x4
09-17-2011 08:31 PM
jcg82
04-07-2007 01:12 PM
hllon4whls
04-23-2006 10:04 AM
johnsalterego
13
06-07-2004 11:04 AM
Quick Reply: C6 Stopped Working
