Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Lift gate won't open 2002 Escape
Old 04-25-2012, 11:49 AM
Ervin2002's Avatar
Ervin2002
Ervin2002 is offline
Is there a manual way to open the lift gate from inside? There's a small access opening at the bottom where I can see the stuck latch, but poking around in there doesn't seem to do anything.
Thanks Erv
Old 04-26-2012, 07:21 AM
tomw's Avatar
tomw
tomw is offline
You will have to remove the 4 screws at the bottom, and then pull the inside panel free for access to the mechanism. If the door is stuck closed, you can manipulate the inside panel loose from the door at the top enough to gain access to work the linkage by hand. It is not fun, but can be done without ruining anything. You may have to get some new 'christmas tree' plastic fasteners if the old ones are too distorted to work.
tom
Old 04-26-2012, 10:20 AM
Ervin2002's Avatar
Ervin2002
Thanks for the response, tomw...but my problem is that the lift gate is locked/stuck in the closed position; I can't get it open. Hopefully, someone has an answer to releasing the latch from the inside of car through that access hole at the bottom. It'd save me a hundred bucks just to have the dealer "look" at it.
Old 04-26-2012, 10:27 AM
martin_csr's Avatar
martin_csr
martin_csr is offline
Yours has an access hole? On the inside? Can you post a pic. Mine doesn't.
From reading other topics, you may have to peel away the plastic from the inside. It's held in place by spring clips... just pull the plastic off at the top so that you can reach in to get at the rod. When I removed the plastic, the hatch glass seemed to be in the way, so I don't know how problematic that might be. I was able to open the glass, before removing the plastic... nothing was broken or anything.
This is a known problem w the Escape, so I removed the plastic interior shroud & drilled a hole in the plastic at the actuator/rod linkage for future access for if ever mine breaks. I plugged the hole w a black plastic plug from Lowes.
2002 XLS. 1st pic: I think the actuator is in the locked position.
Old 04-28-2012, 09:47 PM
Ervin2002's Avatar
Ervin2002
Access Hole...
Sorry, couldn't get a picture, but the access hole is of no use...all that is available thru the hole is the boss that the latch hooks onto. The locked latch finally responded to the key fob and opened, I immediately installed the replacement actuator, which cost me $10; Ford wanted almost $400. They only sell the whole assembly.
Old 06-20-2012, 12:53 PM
nuclearwhiskey's Avatar
nuclearwhiskey
nuclearwhiskey is offline
I had to do this to my escape, I bought the generic and it has worked great ever since.
Old 10-28-2012, 04:55 PM
chap442's Avatar
chap442
chap442 is offline
where did you purchase a generic actuator? I need one
Old 10-28-2012, 07:39 PM
scott91370's Avatar
scott91370
scott91370 is offline
Stereo shops generally carry them - $10ish in my area.
Check this out:
Universal Power Door Lock Actuator Car Auto Best Deal | eBay
fbh31118
1999 to 2016 Super Duty
10-07-2020 08:55 AM
huskyfan68
03-13-2019 04:06 PM
RDockery
1997-2006 Expedition & Navigator
12-21-2015 09:22 PM
blueknight44
Electrical Systems/Wiring
06-26-2006 02:08 PM
thewolfe
02-12-2006 09:13 PM
Quick Reply: Lift gate won't open 2002 Escape
