Question for you lifted guys...
I had a truck several years ago that I put a 4" lift on it. I was a home depot project once in a while type of person back then. The lift wasn't to bad, but at time's it was a PITA. I now have a stocker which I will be putting on a ready lift 2.5" maybe with 285 or 34's. That is it, it will have some appearence but will still be usable and not a PITA to use the bed.
From the minute I first saw a SuperDuty in 1999 I knew I wanted one and nothing was gonna stop me from lifting it, this is what allows me to put up with breaking my *** everytime I put something in the bed. If your thinking lift to join the crowd you will regret it, anything taller than 4" is even worse.... but they look awesome!
I have an 8" lift in mine, but I don't use my truck for work. Practicality played no part in my decision to lift my truck and I absolutely love the way it looks now and all the complements I get on it too. Someone else said it as well, but I use a 7x12 foot utility trailer when I need to haul stuff other than small things that I can toss into the bed. My biggest issue with the 8" lift is I have a hard time getting into the bed. I climb up the side using the tire as a step. No regrets!!!
There are so many factors when considering a lift kit for the Super Duty. What "type" of activity is planned for the truck... daily driver, towing, off-roading?
Going to taller tires will provide greater ground clearance for off-roading but the Super Duty is limited by the wheel well size. The GEN1 (1999-2004) and GEN2 (2005-2007) have the smallest front wheel wells and IMO are limited to 36" maximum tall tires. The GEN3 (2008-2010) and GEN4 (2011-Present) have larger front wheel wells and can accommodate 37" maximum tall tires. All Super Duties (1999-Present) have the same size rear wheel wells, which is another limiting factor in accommodating taller tires.
To provide proper tire clearance, you have two options: Lift Kit and/or Cut-Out Fender Flares. For example, if I wanted to run 38" tires on a GEN1 or GEN2 Super Duty having 33" OEM tires, I could install a 7"-8" lift kit for proper tire clearance. However, if I were to install cut-out fender flares, I would only need a 2.5" leveling kit.
What are the differences between these two options?
A quality 7"-8" lift kit will cost between $2,000 to $3,000. The truck will have a much higher center of gravity. The height of the truck will increase 2.5" from the new tires (38"-33"/2) and 7"-8" due to the lift kit. That's a total of 9.5"-10.5" of additional lift.
A quality 2.5" leveling kit will cost between $800 to $1,200. The truck will have a minimal increase in the center of gravity. The cost of the cut-out fender flares will be between $800 to $1,200 depending on if you paint them. The height of the truck will increase 2.5" from the new tires (38"-33"/2) and only 2.5" due to the leveling kit. That's a total of 5" of additional lift.
The reality is that it is cheaper and more efficient to use cut-out fender flares and a minimal lift/leveling kit when installing 37" and taller tires. You maintain a much better center of gravity and truck height for day to day use.
This guy has a 2.5" leveling kit and 38" tall tires:
This guy has a 6" lift kit and 38.5" tall tires. He could have easily used a 4" lift kit and maybe even a 2.5" leveling kit.
This FTE member has a 2.5" leveling kit and 37" or 38" tall tires.
Painting the cut-out fender flares would make them much more low profile.
BTW, great looking Super Duty!
I said this already, but I'll say it again. For a true offroad rig and not a mall crawler, cutouts are the way to go. Tire clearance without raising the center of gravity. Who cares if you can clear them driving around on the street, I want to be able to stuff the tire up to full compression, wheel cranked, with snow chains on.
#28
If you read the op he simply asked guys with lifts if they are still practical. Specifically he wanted a 6 or 8 in lift. I am not on here to argue how you build your offroad truck. I just was giving my opinion on mine with a 6 1/2 lift. It is not a mall crawler, it is as capable of a work truck as any other I have had if not more. It even is regeared with 4.56 gears. I pull my bobcat, 26' camper, boat, enclosed trailer and I also haul alot of firewood. Just because someone keeps there truck clean doesnt mean they just drive it for show. And to the op yes it is a little inconvienent but to me worth it, to someone else, maybe not.
#29
Do you have any idea what offset rims he's running? I have a 2003 f250 with 2.5" pro comp leafs and 16x10 Mickey Thompson classics, they have a 4.5" off set, I was told 35s would rub on my leafs? I'd like to run 35-37s
#30
4.5" is backspace, not offset. Backspace is only useful if you also know wheel width. Offset is a good indicator because it is the measurement of the hub face to wheel center. You're 10" wide wheels with 4.5" backspace are a -25mm offset, which is plenty for 35" tires up to about 13.5" width. You could run a 37x12.5 and the tires would be about the same distance from the leaf springs at full lock. Rubbing on the fender opening is another story, more negative offset (wheel/tire sticking out further) will result in more fender rubbing, but less leaf spring rubbing.
