Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 04-23-2012, 05:45 PM
DakNSak DakNSak is offline
1958 Ford F-100
DakNSak is starting off with a positive reputation.
'58 F100 brake upgrade help
So I would like to upgrade my master cylinder to a duel cylinder. I have been researching here as well as others. It seams that a duel that will just mount right on does not exist. So that leads to a standard master with some kind of an adapter. Question, what have others done for this popular upgrade? What MC's are a good fit, and how do the adapters look. What about the push rod length? This is a 223 so the air cleaner limits the length of the MC. Thanks
  #2 (permalink)
Old 04-23-2012, 10:14 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
Garage is empty, add now
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
I rarely see posts about these but my '54 gmc has a bendix frame mounted booster that the PO added. This truck has amazing power brakes like you have to tell anyone driving it to be careful so they don't crack their head on the windshield. The PO also uses this setup on a 48 and a 51 chev 1 1/2 ton dumptruck that have run daily for 30 years in his business. I should ask him what they are and where he gets them. No clearance issues on the firewall and man do those things stop...... I'm spending the day with him on Wednesday going on a long trip to pick up another ch**vy for him so we will have time to discuss his power brake setup. I'll report back on Thursday
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #3 (permalink)
Old 04-25-2012, 09:50 PM
1958 Ford F-100
So only Sisson has any knowledge to share on this subject?
Thanks GB, any info/knowledge would be great!
-Derek
  #4 (permalink)
Old 05-04-2012, 11:08 AM
fast58's Avatar
fast58 fast58 is offline
fast58 is starting off with a positive reputation.
Kyle Brazier
I know this is not exactly what you are talking about, but I put power brakes on my '58 f100 while I was changing the front suspension over to a 2003 CV IFS. I used a booster off a 2001 or so Lincoln Town Car (it's very compact) and a master cylinder off of a '98 or so F-150 (it's brake setup is the same as what I have...disc in front drum in rear). I only had to drill a few holes in the firewall to bolt it on and they work fantastically.
Maybe if you can find a master cylinder that goes to a vehicle with drums all around, you could put that in front of a booster and have some power brakes.
Also when talking about pushrod length, it's pretty easy to make your own if you don't already have one (I've done it before). All you have to do is after you have everything installed the way you want it, move the brake pedal where you want it to be. Then just take some keystock (I usually use 1/2" square) and cut it the correct length. Then round off the master cylinder end and drill 2 holes in the other. use some heavy duty metal bracket (1/4" or so) and bolt to the pedal. The reason for two holes in the keystock is so you can put two bolts through the bracket and the keystock to keep it from folding up on you. Of course this is only one of the many ways to skin this cat. Anything similar to that idea will work.
I hope I haven't just typed a lot of information that you already know. Hope it helps a little.
__________________
http://www.ford-trucks.com/forums/im...ine=1324186537
1958 Ford F-100. 351 W .030 over and Speed Pro flat top pistons, Comp Cams 224/226, World Windsor Sr. heads, Edelbrock Performer intake, Holley 750 carb, Roller rocker arms, Proform one-wire distributor, MSD 6-AL ignition.
  #5 (permalink)
Old 05-04-2012, 11:57 PM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
Quote:
I bought a 57 F-350 dually that had the "hydro-vac" behind the seat. It had been a cobbled up old wrecker so I never knew if that was stock or added later. To this day I have driven thousands of vehicles and never one that had brakes as good as that old truck. It would face plant you quick.
Back on the subject. I think a dual reservoir from a 60-70s F-100 with drums could be adapted. It would take a little fab work but not that bad. Also there is a small booster available that might fit in there with the clutch.
Also some of the 60s trucks (my 69 F-250 crew cab for one) had a cantilever booster mount that moved the whole thing up.
  #6 (permalink)
Old 05-05-2012, 09:23 PM
1958 Ford F-100
thanks guys. I decided to put original style back in. A lot cheaper and quicker, maybe power upgrade down the road. But for now, I'm rolln' again!
Tags
1958, 37, 58, 58f100, brake, brakes, cylinder, f100, f1oo, ford, forums, line, master, power, search
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
