NEED HELP! cranks but wont start
Hey guys i have a 94 F350 CCLB manual trans that wont start for some reason, it started a couple days ago after switching out ignition switches under the dash on the column, but today we try to fry it up and it just cranks and tries to start but wont. I am getting a WTS light and tach movement, and have check the #22 fuse and its good. Me and my buddy are just so confused on what it could be
Any help would be appreciated
it did start up that first time after we swapped them out, then a couple days later i was working under the column again and then we tried to start it and it did the same thing before i swapped switches and so i swapped them again and still the same thing. is normal for the fuel filter light to come on while cranking
And to the OP it sounds like a CPS problem. Have you changed that out?
We changed it out with the one from the old column to give it a try before throwing more money into it and it fired right up, but 2 days later got messing around under the column and then tried to start it to see if the clutch would disengage and go into gear so we could take it for a drive on the new clutch and got it trying to start but not running. No but we will try that, is there anyway to test it with an ohm/volt meter?
dustydogg31
18
06-09-2016 02:13 PM
travismoore
15
02-11-2016 05:16 PM
