Why 6th gear b4 out of the driveway????
It's certainly not what cars and trucks of the past have done, but why exactly don't you like it?
To be honest - I like it. Mine does the same, it shifts into 6th at around 38 mph when under light load.
Today I tried it at a pretty steep hill: that truck held 6th gear all the way up at 40 mph. It is actually not necessarily the very best programming for fuel efficiency - dropping it to 5th at that hill makes the green bar go up a notch - but the truck is doing it just fine.
what *I* don't like about it is the immediate downshift to 5th that follows the slightest throttle tip-in. I also don't like the immediate upshift back into 6th when you let up. Staying in 4th or 5th at this speed would be much preferrable. if i had a truck with select shift, i would lock out 5th and 6th in town always.
and if you tip in with any fevor at all, it takes forever for the truck to pick a gear and go ... staying in lower gears longer would improve drivability, IMO.
it's MUCH worse when towing.
just speaking for myself.
I'll chime in.....
It's probably programmed that way for fuel economy, but in my opinion it shifts into every gear way to soon, I don't like being in 6th gear at 40 mph and then have to accelerate and have a lot of hesitation before it downshifts. I think a tuner would definitely work, but the there's a risk of voiding the warranty. I'm considering getting one myself.
Okay, now I'm starting to get it. My dad has a 2010 with the 6R80 but I haven't driven it in awhile. I think that the programming is set like that to improve fuel economy, but of course this comes at the expense of throttle response. So the issue isn't that it shifts to 6th that soon but that it doesn't downshift fast enough?
throttle response is part of it, and the hesitation is a slight annoyance. but more than that is the shift frequency.
i live on a hilly gravel road, and every road in town is hilly as well. On gravel i like to drive around 35ish. maybe 40 down the hills, maybe 30 up them ... just kinda set my foot on the gas and not care how fast i go.
30 means 4th gear, 40 means 6th.... so the whole way home is 4-5-6-5-4-5-6-5-4 .... no joke, in town is about the same, except i tend to keep a more steady speed, between 35 and 40, which will usually cause a 5-6-5-6 shuffle on every hill.
I realize that this is being done in the name of economy, but the marginal gain in economy in trade for driveability is a bad trade.
i will say that this is in a 2010, and the 11's and 12's may be better.
