REAR END, REG LUBE VS SYNTHETIC
when i had my 4.30 gears installed a couple of years ago the guy put in normal 85w-140 gear oil in the rear axle. He said it wont hurt at all, its heavy enough to protect the gears and bearings, it wont hurt MPG like people say it does and i wont heat up any hotter than synthetic. Ive towed my back hoe, dump trailer, bed full of wood, topsoil, pavers since then and my rear has never puked fluid of been to hot. Last summer iinstalled the 2010 aluminum rear diff cover and when i dropped the steel diff cover the 85w-140 came out honey color and clean, no metal shavings or anything
Probably wouldn't hurt anything, but I would stick with the synthetic.
If your usual parts store doesn't have any synthetic and isn't willing to order it for you, it's time to find a new parts store. This is 2012, the SD is far from the only vehicle that requires synthetic gear lube. Heck, even Walmart carries synthetic.
nrvsreck
01-27-2006 07:05 PM
BlueOvalFitter
10-07-2002 05:44 PM
