Turbocharged 300 I6 w/ Propane Conversion
In my quest to make my old 73 F100 4x4 (300 I6) a more affordable daily driver I have begun my research into converting it to lp and slapping on a simple turbo system. I doubt I would ever run more than about 6-7 psi of boost.
I want something that is unique and different and so far from what ive been told and read propane is actually a better engine fuel than gasoline. It also seems it would be alot easier to turbo a propane carb setup than a gas carb setup. Actually LP sounds more simple than a normal gas carb setup does to me...
What do you guys think, am I crazy? Will it work? And most importantly will it be economical? I drive 15k a year and from what I understand the payback would be in the first year.
Gas is $3.65 here and LP is $1.98
There have been propane fueled vehicles around for years but what you are proposing may be more of an experiment. Try your question at FORDSIX PERFORMANCE • View forum - Turbo, Supercharger, and Nitrous and see what happens.
I wouldn't call it an experiment really, the Impco 225 Mixer will support about 8psi of boost max in a blow through setup according to Impco. The 225 and a Model E converter may be pretty close for a stock 300 with a turbo. Turbos and LPG are pretty common in Australia as well. Along with Ford Six Forums that Harte mentioned check out
Alternative Fuels • Index page
Other then that, hit up google and see what you find.
After reading through several threads here and at the Ford Six site, I'm considering trying the 300 turbo in my next project. I hadn't considered propane power, but the engine I'm planning on using is already set up for it because it spent it's entire life as an irrigation engine. I was leaning toward a non-pressurized carb, but many seem to think blow-through is the way to go.
Keep us updated. I'm VERY interested in seeing how you make this work. I'm still in the middle of body work on my Crew Cab, so this project won't get a start before summer, at least.
I am going to do the same thing on my 77 ford. so far i have all the propane stuff, 425 mixer, model L regulator and a 30 gal under bed propane tank. my question is what would be a good size turbo for a max of 8 psi? i have an extra turbo from a 80s turbo coupe, 2.3l 4cyl. im not building a hot rod so dont need a turbo from a diesel, just need some extra power for towing.
The following users liked this post:
302flareside1992
02-21-2015 08:22 PM
302flareside1992
21
02-20-2015 11:40 AM
pud
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
07-07-2006 10:53 AM
