88 wont start?
88 wont start?
i have an 88 f-150 with the 4.9 in it, one day i was driveing and it just shut off. i cant get it to start it makes a weird hissing sound like it might have a bad head gasket, but i cant see why that would cause it to not start? also i touched the coil wire while cranking it, it dident shock me. i though i had a bad coil, so i replaced that and it still wont start? does this truck have much of a cpu? is there any way of testing it? i can hear the fuel pump running and i pulled the line off of the front of the fuel filter and i have gas to that point. Any other ideas?
Thanks for all help,
Chris
Chris
88 wont start?
Its possible that either the computer went bad, or the TFI module on the distributor died.
Replacing the TFI module is only like 35 bucks plus a special socket to make it a little easier on yourself.
Considering you replaced the coil, the two items listed above is what i'd check next.
You can pull codes from the computer with a multimeter or a code reader to see if it set any before it died.
You can also pull the TFI module and autozone or your favorite parts place should be able to test it.
More than likely its the TFI module.
88 wont start?
thanks for your help, what are the chances of haveing a cracked head, i would think that it would still run poorly if i did have one unless i lost compression to all the cylinders. if it was a bad tfi shouldnt i still have power going to the distributer from the coil? when i touch the coil wire with the eninge cranking it dosent shock me?
Thanks again,
Chris
Thanks again,
Chris
on
1 Post
88 wont start?
There is a metal cased relay on the drivers side inner fender panel around where all the wire harness connectors are. This relay is the EEC ( Electronic Engine Control ) relay . It supplies power to the computer. If the contacts are bad or are of high resistance the computer gets no or low voltage, Ford computers need 10 or more volts. This will cause the engine not to start ( no spark) or to die at the worst possible moment, like in the center of an intersection. The relay is only around $15 from Ford. Could also be the module on the dist, there was a recall on it, would die when hot but restart when it cooled off. Bad coil , if you don't have voltage you won't spark. You may not be able to measure the voltage to the coil . The voltage generated by the Ford Module to the coil is a high voltage spike. Check the coil with volt /ohm meter to see if it is open, or better yet read the service manual and see how they check it. The engine should still run even if the head gasket is leaking , you may hear the compression leaking past the rings when you are cranking the engine in a no start condition , especially if the engine has not ren is some time and is worn. The above pertains to a stock Ford with EFI and the electronic dist.
stractor
88 wont start?
If your getting shocked just by touching the outside of the coil wire you need new wires Pull a spark plug, do you have any spark? Check the schrader valve on the fuel rail, do you have fuel there? Are all the grounds hooked up to the engine? Maybe one came loose..
88 wont start?
Was it like the truck just ran out of gas? Mine did that the other day and I replaced the coil, cap, rotor, wires, plugs..all to no avail. Check your schrader valve. Mine only lets out air and no fuel comes out so I think it's a bad pump. If you find out your problem, let me know so I can get mine fixed too!!
mousey831
03-26-2011 09:28 PM
seawulff
22
11-12-2006 06:53 PM
shaun2fast
15
10-11-2003 02:40 PM
