1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Cold Ac when Idle and Hot when driving? Any Ideas
Old 03-29-2012, 08:48 PM
partslady's Avatar
partslady
partslady is offline
08 7.3 F-350 at Idle A/C blows cold air. Start driving and A/C begins to blow warm air. HELP Idle ac cold ,driving crusing warm air.
We have checked amount of freon, check for restriction in orifice tube, cleaned all heat exchangers, and now we re just frustrated because this is just backwards for a normal airflow problem. Has anyone seen this before? The truck is equipped with a big bumper and we thought at first it may be causing the problem
Old 05-14-2014, 10:49 AM
DieselDowdy's Avatar
DieselDowdy
DieselDowdy is offline
Did you ever find a fix for this. Mine is doing the same thing. And is driving me mad
The following users liked this post:
Old 05-14-2014, 12:31 PM
VindexInjuriae's Avatar
VindexInjuriae
VindexInjuriae is offline
Check your AC clutch engagement, the clutch may be worn enough that it will not hold lockup at higher RPM's. I went through the same problem with my 99, cold when idle & low speed & started blowing hot on highway. AC clutch was worn enough that it couldn't hold when driving. Removed a shim & it works perfect now.
I got the info on the exact procedure for measuring spacing of clutch on a web search, don't remember the site but I can look for it later if y'all don't have luck locating it.
I do remember to test it, all you had to do was drive with AC on & when it started blowing hot, pull over, pop hood & see if clutch is engaged. If not, tap it with a solid object & if it engages, bingo.... you know what's wrong. Just be careful tapping the clutch when the engine is running, don't drop your tappy tool lol
Old 05-09-2018, 06:26 PM
Kathy Warren's Avatar
Kathy Warren
Kathy Warren is offline
AC cold at idle and hot while driving
Just had a new compressor installed for over $1000 and it’s still not working. The auto shop said I now need a $600 tune up because the truck is in “limp” mode. Does this sound right?
Old 05-09-2018, 06:32 PM
Fordbronco1995's Avatar
Fordbronco1995
Fordbronco1995 is offline
Clutch fan?
Old 05-09-2018, 08:45 PM
maticuno's Avatar
maticuno
maticuno is offline
If your vehicle is older and uses vacuum, you could have a blend door actuator problem if you have a vacuum leak.
Djosbun's Avatar
Djosbun
Djosbun is offline
Definitely not right! Some of these mechanics stories are just dreadful!
​​​​​​​— Dave
meier63
07-01-2019 09:53 PM
ScottInTexas
21
11-19-2015 12:20 PM
Swingshiftworker
08-29-2009 08:53 PM
haulingboat
32
08-24-2007 09:06 PM
Hburger
05-29-2005 10:38 AM
Quick Reply: Cold Ac when Idle and Hot when driving? Any Ideas
