Spark pug ejection system
I'd like to know what you guys do in advance to prevent spark plug ejection in a 5.4. I worry about being 200-400 miles away towing my race car trailer and ejecting a plug. Do you check torque occasionally or pull them and look sometimes. Or do you just use Bravado and go another 100K and fix it when it happens. I've never helicoiled one, and don't want to be at the mercy of a { on the road} mechanic if it happens. Whatcha think? 01 superduty 5.4 auto, 4x4, 151K. supposedly changed plugs around 100K, and fixed 1 ejected around 120K. I just bought truck.
Yes they are expensive if you arent in CA. But if you email them and ask what torque they install at it will give you a better idea of what you should install your at. Last i checked they have never had one back out after they installed a plug be it insert or just a preventative swap of plugs.
Some guys recheck torque every 10K-20K miles. Mine made an obvious ticking noise before it launched both times, I tightened after the first occurrence but it still spit and I knew it was going to so I took it easy, no WOT and babied it for a few months until it spit again. If I was going to be that far away a lot I'd probably look into either inserting all the plug holes or getting new 8 thread heads. If you hadn't had any launch I wouldn't be as worried but you don't know how many of them were overtightened since one went. I'd also say at 51K miles you are about due for another set.
+1 on this ^^. Autolite is an acceptable alternative but just about the ONLY one! Too many bad experiences with other brands however being fair Krewart current has a thread about installing and driving with Bosch platinum plugs, updating occasionally with interim reports.
In the meantime save yourself some aggravation and go with something proven to be reliable and works well.
I replaced the plugs today preventively with Motorcraft Platinums. I blew out the plug hole with compressed air, used anti seize, and dielectric grease on the boot ends and on the boot where it goes into the head for a water seal. Took probably 4 hours or so, trying to do everything right. Torqued them to 15# even though another source said 28# and no anti seize. Hopefully I can avoid any ejection with preventitive maintenance. By the way, what a #@&&$#!!! #4 is!!! Mirrors, flashlights, move lots of stuff and feel for it.
I have used this kit many times at the shop and have not had any problems.
