5.4 question... now with Answer
Old 03-31-2012, 08:02 AM
Ironhand03's Avatar
Ironhand03
Ironhand03 is offline
Also.
When the FRPS is blown it will often NOT set a code because the electronics are fine.
Test to check:
The FRPS is attached to the rail and is small, black, and has an electrical connector on top of it with a vacuum line attached to the body of the FRPS itself.
Pull that vacuum line off the FRPS, DOES IT SMELL LIKE FUEL? Yes=FRPS is blown.
Pull the engine oil dipstick, DOES IT SMELL LIKE FUEL? Yes=FRPS is blown.
If the truck has issues starting and maintain running, shut the truck off, then UNPLUG THE FRPS. DOES IT RUN BETTER OR NORMAL WITH THE FRPS UNPLUGGED? YES=FRPS is blown.
If you do have a blown FRPS then replace it ASAP,like yesterday, and do an oil change ASAP as well. Gas will wash down the cylinder walls=VERY BAD & is horrible for engine bearings.
Old 03-31-2012, 08:08 AM
Ironhand03's Avatar
Ironhand03
What year and model truck do you have?
EDIT: NEVERMIND 2004 F-250 5.4L
Old 03-31-2012, 08:18 AM
Ironhand03's Avatar
Ironhand03
Ok here you go.
2004 F-250 5.4L 2 Valve.
Minimum Fuel Pressure 30psi.
Normal operating range 39-42psi.
Maximum Fuel Pressure 50psi.
Old 04-02-2012, 08:19 AM
shaneinga's Avatar
shaneinga
shaneinga is offline
Thanks. Good info there!
Old 04-02-2012, 08:29 AM
Ironhand03's Avatar
Ironhand03
Not a problem. If you need anything else post up in here and Ill do what I can to help out.
Did you get the truck up and running now?
Old 04-02-2012, 08:32 AM
shaneinga's Avatar
shaneinga
Yeah after they put a fuel pump in it, it is running great.
For now anyway. LoL
Old 05-07-2012, 08:10 PM
kemorris's Avatar
kemorris
kemorris is offline
Vacuum Leak Check?
Also plan on getting a propane torch and some tubing to see if I can find a vacuum leak on it.
Can someone please explain this process?
Old 05-08-2012, 05:37 AM
shaneinga's Avatar
shaneinga
******** style="height: 390px; width: 640px"><param name="movie" value="http://www.youtube.com/v/9CPqbaSgcok?version=3&feature=player_detailpage">< param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/9CPqbaSgcok?version=3&feature=player_detailpage" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="360">*********>
bucks150
05-26-2020 09:52 PM
latechbanjo
26
11-26-2017 10:14 PM
bamaf150
2004 - 2008 F150
09-11-2013 03:03 AM
jvaski
1997 - 2003 F150
20
04-07-2013 12:32 PM
sconut1
23
07-09-2010 09:41 PM
Quick Reply: 5.4 question... now with Answer
