Wheel well rust repair
Old 03-21-2012, 06:12 PM
guessrow's Avatar
guessrow
guessrow is offline
Hello,
I have an 04 f150 that is starting to show some rust in the rear wheel wells. Right now there is just a bit of rust where the painted panel is seamed to the inner panel around the arch, but I can see small spots where the paint is starting to bubble about an inch out on the outside of the panel. I want to keep this thing looking nice for a few more years; what should I do?
I'm a very good welder, can hold my own when turning wrenches, have done lots of metal fabrication as well as painting with a cup gun, but I have very little autobody experience.
I am thinking there is rust between the inner and outer panels and that removing the surface rust and repainting would be a very temporary repair, correct? Could I cover it up with some sort of wheel well liner? If so, how to I slow the existing rust? Is there any sort of partial preformed steel panel/well that allow you to cut off the rusty stuff and weld new stuff on? I'm a little leary of the last thought- I could do the fabbing, but not sure how I'd do getting it back to 'smooth'
TIA for suggestions- jim
Old 03-22-2012, 04:17 PM
Greg B's Avatar
Greg B
Greg B is offline
I'm not sure of a patch panel on this body style, but I'm sure 1/4 panels are available from Ford or a vendor such as Crash Parts. It might be less expensive to locate a used rust free bed and paint it to match.
Old 03-23-2012, 03:01 AM
DieselBeast01's Avatar
DieselBeast01
DieselBeast01 is offline
I would say that the used rust free bed would be the best route. You can probably find one pretty cheap.
I guess I am just used to living down here in the south, but it amazes me that truck that is only 7-8 years old can have rusted panels on it. You can get away with washing a vehicle once a year down here and never have to worry about rust.
Old 03-23-2012, 10:05 AM
Coskid's Avatar
Coskid
Coskid is offline
While that is true you can get away with washing it in the south once a year but you should rinse the wheel wells every so often.
guessrow
Paint & Bodywork
03-25-2012 05:09 AM
CdnSoldier
Paint & Bodywork
06-12-2005 07:14 AM
69Charger
Paint & Bodywork
08-21-2003 06:04 PM
VIBR8R
Paint & Bodywork
07-11-2003 10:02 PM
scootin
1978 - 1996 Big Bronco
03-31-2002 10:58 PM
Quick Reply: Wheel well rust repair
