Cant get my tires off!
Old 03-20-2012, 11:28 PM
FordingNewGuy's Avatar
FordingNewGuy
FordingNewGuy is offline
Started on a front brake job on my '95 250 4x4, jacked it up, put it on stands, took off the lugnuts and cant get my tires off. Admittedly, I have waited too long to do the brakes/rotors but, WTF? I should still be able to get the tires off. I beat the heck out of the with a sledge, tried heating the rims around the studs, then beating, can't get 'em off. Any ideas...
tks
Old 03-20-2012, 11:35 PM
blkF250HD's Avatar
blkF250HD
blkF250HD is offline
Do you have steel or aluminum wheels? I usually soak the area around the hub and studs with PB Blaster and let it work for a few minutes. Then it's usually on to the soft face hammer (plastic) and I hit them from the back side. Hit, rotate, hit, rotate. Otherwise a large pry bar (AKA "man bar") placed between the rotor and the wheel can sometimes get them loose. You may need a helper to hit the wheel while you pry, or vice versa. Obviously, be certain the truck will not move while you are under it.
FWIW a few minutes with a die grinder make life easier in the future. When I had mine off the hubs and flanges on the wheels got cleaned, and everything (except the studs) was anti-seized.
Phy's Avatar
Phy
Phy is offline
Yeah, sometimes they get rusted on pretty badly...
As a last resort, you can loosen the lug nuts & drive a short distance...
Old 03-20-2012, 11:47 PM
Dave804's Avatar
Dave804
Dave804 is offline
Ran into the same problem over christmas brake. Warped rotors on a benz with almost 500k miles that'd be sitting for awhile too. Lugs out, axe handle against the inside of the rim, beat with hammer. Rotate wheel a little, repeat and keep going. Finally the wheel popped off. Brake cleaner and then a wire wheel will clean up the inside of it.
FordingNewGuy
okay, Thanks!. I will try both. just wanted to make sure I wasn't missing something. The rims are aluminium btw.
Old 03-21-2012, 12:42 AM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
i used to lay a block of wood up against the inside of the rim and get a BIG hammer and give it a few good whacks then rotate tire and a few more whacks... keep repeating till it gives
blue oval fan
6.7L Power Stroke Diesel
03-11-2016 02:59 PM
bbsitum
1997 - 2003 F150
05-16-2015 08:01 AM
RichFEH06
Escape & Escape Hybrid
04-10-2009 04:45 PM
Brother Les
03-11-2009 09:16 AM
artfuldodger
1999 to 2016 Super Duty
10-20-2007 06:54 PM
Quick Reply: Cant get my tires off!
