How to drain the oil in the HPOP
You will just need a smaller hose. You can also pull the IPR but that makes a mess in your valley. Why are you wanting to change it?
Brake Bleeder & Brake Bleeder Vacuum Pump Kit
Or
Sears: Online department store featuring appliances, tools, fitness equipment and more
These would work, I believe Auto zone, checker, Orielly etc... sells the same style as well
Or
My truck misses about once every 1-2minutes when idling, dealership said I needed the resevoir cleaned, a new HPOP, and a new IPR. Instead I replaced my leaking ICP, old CPS, and ordered a seal kit for my IPR from you so I can take it out clean it, replace the seals and reinstall.
Truck was also shifting hard and puffing white smoke, but that seems like it has gone away now.
Clean the IPR if you really feel so compelled the oil in the reservoir will drain out into the valley. The dealer is trying to upsell you. Stuff a few clean, absorbent rags in the valley prior to pulling the IPR.
whats a full service consist of?
And how are they completly seperate and what am I supposed to use the synthetic hydraulic fluid in? I use synthetic motor oil (Rotel T6)
sorry little confused.
I take a old pump out of a soap or shampoo bottle, maybe even a gojo bottle and pump it into a jug. Normaly the same jug the pump comes out of. Just for reference and clarification the hp oil comes from the lp oil pump right out of the bottom of the oil pan. Now the oil in there may not be getting circulated all the time but eventually it is. I do pump mine out occasionally but it ain't necessary. Just gets an extra quart out or so. One thing to remember though, if you empty it, be sure and refill it before you crank it. Otherwise you could force air in the oil rails and cause some rough running till its cleared out. Also so the hpop isn't run dry for any length of time.
The oil in the HPO res is changed every second the truck is running. There is no reason to clean anything.
If it makes you feel better the best way to clean the HPO res is to remove it. Messy, but best way.
Sorry, going to be an a$$ here too. I have had this convo with Bob from DieselSite in person while looking at a HPOP reservoir. I understood what he was telling me looking at the unit while we talked, yet the fact remains that I pull out some serious crap from my HPOP. I have posted about this in the past and even shown pictures so garbage does collect there somehow. Next stop is IPR and then injectors. I say do what makes you feel good. It does not take much effort. How many times have we read about folks changing oil and it is black in no time? Either they have bad blowby or the contaminated oil remaining in the rails and HPOP is enough to pollute the fresh stuff. Or the cooler is full of crappy oil. At any rate, once the system has crappy oil it takes several changes to clear it up. Oh well, it has been a while for me and I am just posting about what I see and do. A bit of trivia here, anyone know what the pressure is in the stock HPOP? What does this do to oil, fresh and older? How about the unfiltered oil being sent upon every startup? IMO the best way to combat this is to keep the oil clean at all times. I have done this for quite some time yet can pull the dirtiest oil from my HPOP. Draw your own conclusions from this.
the dealership said that my resevoir needed to be cleaned and another member on here (or a link to another site) mentioned sucking out the oil putting in a fresh quart letting the truck idle for 15min and then doing that twice more would help clean out the resevoir. Agree? or not so sure?
So if it's already changing rapidly as the engine is running, then how is manually changing the oil by hand going to fix the issue?
See what I'm saying? Just showing that you've been given some bad advice that is simply a waste of your time, and will prove to not resolve your issue whatsoever.
A person should never have to clean out their HPOP reservoir. I've posted a picture of my HPOP reservoir freshly removed from my engine, and snapped it without ever cleaning it. Looks brand new inside, and this was with more than 140K miles:
In addition, the oil in the HPOP is not "dirtier" than the oil in the rest of the engine. Several folks even on this forum have directly pulled oil samples from the oil pan as well as the HPOP reservoir, send them off for oil tests, and the test coming back showing it's the exact same oil. Again, if yours differs from that in any way, then you have major engine problems that need to be addressed soon.
