Turbo Pedistal Leak
Try Bob here:
Replacement O-rings for Ford Diesel Engines
He's close to you also, and top quality service.
Opps, he's out also.
We should have up-pipes back in stock soon. They are on national backorder but they say we should have a pallet soon.
Glow plugs -
Riffraff Diesel: Motorcraft Glowplugs
Glow plugs -
Try Bob here:
Looks like Clay has everything I need except for up pipes and the blank pedistal. Any other good venders I should check. Im ready to order this stuff and get to working on it already.
http://http://www.riffraffdiesel.com...Store_Code=RRD
I think my list is done. . I may have to wait on the T500 HPOP and Hutch and Harpoon.
Plus I still need to buy fluids and a few other smaller ticket items. $$$
Hope Im not forgetting anything.
Chet
Im getting excited and a little nervous about the project. I think I need all the luck I can get.
You will be fine on the installs. It really isn't that bad as long as you have a decent set of tools. Here is the breakdown of how to do it.
Remove the Fuel Bowl
Remove Spider, Turbo, and Pedestal
Replace the Up-Pipes
Replace the HPOP
The Up-pipes are actually not a hard item. They can be a little bit of a pain due to access, but if you have a helper to hold things and a decent supply of long extensions, you will find it fairly easy to install. Just DO NOT tighten them onto the manifolds until you get the turbo reinstalled and the collector clamped onto the turbo. You can leave the bolts loose and tighten them after the turbo is fully installed. Just follow the instructions above and you will find it should go smoothly.
Replace the HPOP
Woodnthings.
Nice, Thanks for the links.
Im totally new to working on diesels but have been wrenching on N/A gas motors as I have needed to for years. Ive got a pretty decent collection of tools so I hope it wont be to difficult of a project.
Im pretty much doing everthing that was suggested by members that posted on my thread and know far more than me.
Blank Pedistal
GTP High Flow Outlet
Bellowed Up Pipes
T500 HPOP
HPX
Frx
All new intercooler boots and clamps
Plenium Inserts
CCV mod
Big Boost Air Filter
Fuel filter
Glow Plugs and checking valve train torqs
50 cent mod (still Looking for info on how to do this)
Im going to wait on the hutch and harpoon mod for now. I dont see a reason why it would be easier to do now and Im running out of funds and time.
Im still on the fence about installing Lpop M208.
Blank Pedistal
Bellowed Up Pipes
T500 HPOP
HPX
Frx
Plenium Inserts
CCV mod
Fuel filter
Woodnthings.
Blank Pedistal
Bellowed Up Pipes
T500 HPOP
HPX
Frx
Plenium Inserts
CCV mod
Fuel filter
Blank Pedistal
Bellowed Up Pipes
T500 HPOP
HPX
Frx
Plenium Inserts
CCV mod
Fuel filter
Did loose a water pump about 200 miles from home and was FORCED to have the stealership replace it for me.$780ouch and they didnt even empty and replace all the coolant.
#30
GoCamping
17
02-24-2006 10:28 AM
