anyone ever use this cam? sum-K34052
have been doing some cam shopping and was looking at the summit racing k34052 and was wondering if anyone here has any experience with it and how it compares to other cams like the comp 268h. also anyone know how to id a cam the one in my rebuilt motor i just picked up has very little identification other than between the last lobe and the end it is stamped 156 thats about all i can find on it
That Summit cam is what I call a "square" cam - both intake and exhaust timing and lift are identical. (Advertised Duration 272/272, Lift .533/.533,)
The comp cam is 268/268 and .494/.494 lift. Almost the same duration, but less overall lift. It'll be easier on the flat-tappet lifters than the summit cam.
Lobe centers I can't find for either cam, not sure if there is some fundamental difference there.
I ran a 292/292, .554/.554 Wolverine cam in my 390 - but I had put bigger CJ-size exhaust valves in the heads with the stock intake valves and ran 1 7/8" long-tube headers.
The Summit K34053 is the same cam as the Crane 272* Energizer. I used one in a 68 Merc 390 with 10 to 1 compression. Good cam. Just a hint of a lope at idle when cold, allowed the motor to use 89 octane fuel with the 10 to 1 ratio. Pulls to 5500 with stock heads and springs. The LSA is 110*, duration @ .050 is 216*.
'89F2urd
10-26-2011 06:13 PM
pcullins
08-07-2004 07:48 AM
fordman428
12-05-2003 03:51 PM
jwtaylor
09-12-2003 02:49 PM
