I put the Edge Evolution CTS in my 03 and it keeps throwing 2 codes that I can't figure out. The first is P0306 which is something about a virtual memory fault. The second is U0306 which says ficm software incompatible. I just got the ficm rebuilt by ed up at ficmrepair.com and it was throwing those before I sent it out. Any ideas guys?
P0306 is a cylinder misfire due to loss of compression according to the code list. Similar to a contribution/balance code. This code I would worry about.
U0306 is nothing to really worry about. It just means the PCM and FICM weren't flashed together.
Oops I'm slightly below average intelligence because I can't read the code right. lol It was actually P0603 NOT P0306. I think that was caused by my batteries being crappy and should clear itself after 40 no fault starts. Thanks guys
You'll be fine then. No codes to cause any concern.
