how does the fuel rail disconect from the injectors and fuel lines. is it pressuriezed if so what do i do to take the pressure off. doing this to remove the lower intake.
Bleed pressure out of the system using the schrader valve on the rail. Then disconnect the fuel lines using a disconnect tool. After that unbolt the rail from the intake and pull up. When you reassemble replace all the o-rings and lube them so they won't tear.
Petroleum jelly works good when you put them back together and be VERY careful when doing so. If you make even the tiniest nick in an o-ring fuel will spray all over the motor when you pressurize it.
You can find the disconnect tool at most auto part stores. I have the metal and plastic versions. Sometimes one works better than the other.
They might be a pain to disconnect, so spray some lubricant around the fitting, where to rail connects to the line/ and let it sit for a few before removing the lines.
