rear end, help!
The 8.8 and the 9 inch are both good rearends. They got away from the 9 inch because of fuel mileage, the 8.8 is more efficient.
Either rearend should bolt in if it comes from a 80 thru 96 f150. The 9 inch will be found in the earlier models. Double check the length of the nose on the different rearends, you may need a longer or shorter driveshaft if you change from the 8.8 to the 9.
let me back up a little bit. id like to get slectable lockers so that i can leave them unlocked while on pavement and lock them when its needed. ive heard about the eaton e lockers, air locker, and limited slip but those sound a bit expensive. i dont know which one is the best and which is cheapiest.
Well none of the selectable lockers are "cheap" IMO. Any one of them are going to cost $700+ not including installation so add another $250 or so. Then if you decide on the air locker you'll also need some kind of air supply to operate it. So all included your looking at $1000+ easy. The electric would be about the same minus the air supply but, they have kind of a reputation of not being that good, don't know because never owned one. But Jeep and Toyota both use electric lockers so maybe they got them working better.
bigblack89
26
02-29-2004 01:16 AM
