77 4x4 front end rebuild
Old 03-18-2012, 11:54 AM
Famousamos's Avatar
Famousamos
Famousamos is offline
Hey guys, my truck is in desperate need of some front end work. The steering has lots of play in it and is very loose. Ive found a C-Bushing kit at Bronco Graveyard, what else is needed to complete the rebuild. I won't be doing the work, only purchasing the parts.
Thanks
Old 03-18-2012, 01:01 PM
74ford4x4's Avatar
74ford4x4
74ford4x4 is offline
I'd replace the tie rod ends and ball joint to.
Old 03-18-2012, 01:41 PM
Thesteeleboy's Avatar
Thesteeleboy
Thesteeleboy is offline
On all my 1977 F150's, I changed the tie rods over to 1978. I would hate to guess how many 1977 tie rods Ive bent rock crawling and getting wild, due to the fact that it comes new with a bend in it. That is the week link in a 77.
Old 03-18-2012, 02:36 PM
Famousamos's Avatar
Famousamos
Thanks for the tips, I figured on replacing all the parts mentioned. Just didn't want to miss anything.
Old 03-18-2012, 08:42 PM
bamaf150's Avatar
bamaf150
bamaf150 is offline
Does the kit come with tracbar bushings? I'd bet money those are wore out too.
Old 03-18-2012, 08:50 PM
Famousamos's Avatar
Famousamos
Yea, it includes C-bushings, trac-bar bushings and strut arm bushings.
Old 03-18-2012, 09:49 PM
Thesteeleboy
You will also want to check the bolt that secures the track bar to the axle and make sure the bolt hasn't worn, or the hole in the axle tube is still tight on the bolt. They tend to wallow out.
Old 03-18-2012, 10:54 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
2X.. change over to the 78-79 T-style drag link and tie rods.
Poly shock eye bushings and poly tie rod boots are worth considering.
Old 01-20-2013, 04:38 PM
gfx4t's Avatar
gfx4t
gfx4t is offline
If your slack problem isn't resolved after rebuild, change out the steering gear box also.
Old 01-20-2013, 05:46 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Received 3,339 Likes on 2,483 Posts
Ck the rag joint and the steering shaft, and wheel bearings since you are right there.
"Red Head" steering had a great rep as far as steering boxes.
http://www.google.com/url?sa=t&rct=j...41248874,d.aWM
harley4jcs
03-29-2015 08:37 PM
Copedawg
60
05-30-2011 02:35 PM
smokestak
07-29-2010 07:10 PM
LARIAT 85
02-11-2008 09:02 AM
cookie88
21
08-03-2006 09:29 AM
Quick Reply: 77 4x4 front end rebuild
