Overdrive light flashing when decelerating
The F250 and F350 never came with an AOD from the factory. Yours is an E4OD.
Your best bet is to check for codes: Fuel Injection Technical Library » How To Run a Self-Test
Or purchase one of these to display codes: Equus 3145
Clean the pins in the connector. Use some contact cleaner. Sometimes you have to get a little more aggressive, I use a small screwdriver from time to time.
Zack12
12-16-2012 08:02 PM
skrinar70
10-26-2007 08:46 PM
