Possible rocker arms for an idi.
Old 03-18-2012, 10:49 AM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
Whenever someone here gets 'em installed, POST RESULTS!
Old 03-18-2012, 12:18 PM
88 Ford IDI's Avatar
88 Ford IDI
88 Ford IDI is offline
Before they can do all the pricing stuff, they have to make sure the ones they think fit actually do. I do know the base price was $400-450 like Justin said. That is what they also told me too. That is a decent price in itself so a group rate will make it even more affordable...
Old 03-18-2012, 12:19 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
what are you going to gain?
Old 03-18-2012, 12:26 PM
88 Ford IDI
Less parasitic drag due to being roller type and also being lighter weight too which will make more horsepower. Thay also probably wear better than stock too. There is a reason hot rodders put um on their gas engines.
Old 03-18-2012, 12:39 PM
NMB2's Avatar
NMB2
NMB2 is offline
You're not going to get noticeable power increase from just the less drag IMO.
However, it will stop side loading the guides, so they will last longer. It will stop breaking the tips of the valves like the stockers do, and they will oil the top end better.
As for power increase, its going to allow for more lift. My turbo cam is as big as you can get on a regrind, so I'm going to go from the stock 1.5 ratio up to a 1.6 ratio.
Old 03-18-2012, 12:47 PM
FORDF250HDXLT
well with the low rpms of the diesel, and stock cam id never worry about the stock 7.3l rockers.we have no issues to speak of of course.
however i went with higher ratio rockers when i swapped cams for a gas engine back in the day.i know there's a benefit there.
those running stock cams,could probably find better uses for the $,wouldn't you say too or?
Old 03-18-2012, 01:02 PM
88 Ford IDI
Its just my speculation but I think with how much you milled your pistons you will be good as far as lift goes. Do you think that a stock compression engine with your cam can handle the 1.6 ratio?
Old 03-18-2012, 01:12 PM
88 Ford IDI
Ya I definitely understand where you are coming from. Most the guys who are running a stock cam aren't looking for that type of performance anyway. But it would be a mod that some might consider instead of a cam swap because they don't have to take stuff apart quite as far as with a cam swap. I do think both together would perform well though.
Old 03-18-2012, 03:58 PM
NMB2's Avatar
NMB2
NMB2 is offline
Stock 7.3 rockers break the valve tips, and wear the guides crooked. Even at low RPM. They also have poor oiling characteristics.
For someone rebuilding an IDI and wanting it to "last forever" the roller rockers could be a cheap investment.
For someone with an IDI wanting to get more "performance", yes there is better things to spend that $450 on than roller rockers.
Old 03-18-2012, 06:48 PM
Ford F834's Avatar
Ford F834
Ford F834 is offline
Sounds good to me! If I run typ4's torque cam, would I want to keep the stock 1.5 ratio or something else? Let me know if we get a pool going for that group rate (if they fit...) I'm interested.
Old 03-18-2012, 06:55 PM
91dirtydiesel's Avatar
91dirtydiesel
91dirtydiesel is offline
As you already know Justin, I'm in
BadDogKuzz
16
09-09-2011 04:01 PM
C-Leigh Racing
28
01-10-2009 10:07 AM
S.P.
05-07-2008 07:24 PM
Bikeitswift
09-22-2004 10:23 PM
d1a2n3e
10-12-2002 12:03 PM
Quick Reply: Possible rocker arms for an idi.
