2005 Wheels on a 2012?
I really like the aluminum semi-truck wheel look that these offer, and this brings up the question of will they fit? Will the sensors fit?
Points to anyone who knows for sure.
Ford Truck 275 70 R18 Tires and Wheels (4)
Tried that with a set of MotoMetal wheels from my 2004 F250. Didn't work because the offset is significantly different. I'd double check the offset on your wheels and the factory ones before swapping. I found out the hard way, took both trucks in, had them swap the tires and TPMS sensors to the old wheels and the new tires to the old wheels. Drove it off the lot and found it would rub at full lock. Had to go back the next day and get them all swapped back.
I am not so sure on the TPMS sensors. Wheels not designed for them generally don't accept the sensors. I have not seen Fords latest sensors but the ones from '08-'09 may not work. I would reccomend looking inside the wheel for a square cut out around the stem area that provides the needed clearance.
