So what did you do to your 6.0L today?
#7201
Oh and it Definatly won't help with mpg.... If anything will make it worse as you'll be tromping in it everywhere just to hear the sweet call of the 6.0 yetti lol
#7203
My 6.0 is much happier, especially with the hot tunes I run.
You basically don't hear it in the cab until you mash it
#7205
#7206
#7207
Well I went in and picked up a transmission part and the oil
to put back in after I pull the pan and that stupid solenoid
that is spending my money. They happened to have 1 of the
only 2 solenoids in town. But they did not have the 08 pan
Oh well you win some you loose some. Might do the pan next
go a round for the 10K dump and fill.
Sean
Marry Christmas
Sean
Marry Christmas
#7211
Also, some aren't made to come apart so you need to drill out plastic rivets and upon reassembly use screws to hold it together. It's been awhile since I've done any so the above is to the best of my memory.
#7212
Done it to multiple vehicles. Disassembled the actuator, removed the motor's thermistor plate, wrapped it in foil, and then reassembled. The first Excursion I did this to was over 8 years ago.
First time I have experienced this on a Ford truck. Looks like I found my Saturday project.
Josh
#7213
The trickiest part was prying on the retaining clip and sliding the actuator off its mount. After you do one the rest won't take more than 15 minutes each. If you have the ones with the melted plastic rivets holding the case halves together, make sure you pre drill the holes for the screws when you reassemble. Wish I had pics but It was probably 5 phones ago and the pics are long gone.
#7214
Remember what sized screws to use?
Josh
#7215
