So what did you do to your 6.0L today?
jack mine leaks 1qt every 3500miles...
from the noises i heard coming from the front end today it seems im going to be working on the truck this weekend.. driver side seems to be making a grindy noise (suspecting wheel bearing there).. pass side i have some brake noise.. seems the calipers dragging a little bit there.. was hard to turn the tire..
I had a number of paragraphs under the "ad" explaining what the diaper was really for, but pulled it as I questioned if I was posting info that was something I should not have.
There's no expectations of anyone really using it, although it was under my truck for over 12k miles.
As far as brakes just check each component as you take each off to see where the problem lies. And remember some pads have nubs on the back for noise insulator retention which can chip the phenolic Pistons if the piston are not retracted fully.
No, I'm waiting for the ordered OTC tool to show up so I can remove the rockers and inspect them and the pushrods. Latest ship estimate is 3/28. Kept waiting for a cheap version to pop on eBay but it never happened.
From the data I collected in the fall/winter from IDS (when I thought it was just an injector issue) it looks like I need to replace 2,4 and 8 from the uncompensated data graphs. I made vids 'cause I thought I'd collect data to show what cold weather stiction looked like, if Archoil would fix it, and if not how an injector would.
And I've waited as I didn't want to get this motor open then have a weather delay until this old body wanted to get back in.
Jack the lower cost rocker tool won't show up on Ebay
because I got it about 2 years ago/ Worked really hard
on finding it and jumped on it when it showed up.
i dont think its the noise makers... the passenger side tire when i jacked it up is hard to turn like the brakes were still gripping it.. ive had glazed pads before that squealed... just havent had time to pull the tire off yet to really look at it... might get to it on the weekend...
because I am such a cheap ***.
Mine has less shine on it bout it's all there.
OTC 303-1170
