Smoke: diagnostic assistance needed ...
Old 03-10-2012, 08:17 PM
98SurplusExpy's Avatar
98SurplusExpy
98SurplusExpy is offline
So, @ 50K miles, I'm noticing some smoke ..
1) When "getting on it" (like 20 psi Boost & 3K RPM), it'll leave a puff of black smoke when it really starts to throttle-up, then it stops smoking.
2) On a cold morning @ start up, it'll puff out a cloud of blueish-white smoke that has that sweet diesel smell.
I run an Edge Insight ... all temps are in spec & hadn't had any codes in a long time. The International 6.0 runs good overall. What is the smoke trying to tell me?
Old 03-10-2012, 08:25 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Hows the Coolant leval
If it smells like coolant the egr cooler might have sprung a leak Better pull the EGR Valve out and check for coolant in its chamber
A sweet smell in the exhaust usually means Coolant problems
Old 03-10-2012, 08:34 PM
98SurplusExpy
Coolant level is steady .... I put a piece of tape on the degas and check it for level consistency from time to time. It's always dead on.
I've had both the oil cooler & EGR cooler replaced twice already. Each time for temp differential issues.
Old 03-10-2012, 08:55 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Well if thats the case doesnt sound like the EGR Cooler went bbad
Have you verified the coolant leval since the smoke started??????????
I've had both the oil cooler & EGR cooler replaced twice already. Each time for temp differentia issues.
Thats good But doesnt mean the Egr Cooler is good
It could have a Manufacture Defect
A Bad injector could cause smoke issues to
Old 03-11-2012, 03:02 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
CCV Reroute time
if I do alot of short trips, my truck will blow smoke. I pulled my intake boot off and the interior of the intake and boots are full of oil from the CCV
if I drive the truck for longer trips and harder runs, the oil cleans up and she won't smoke at all.
pull off the intake boot and look down inside the intake manifold. see how much oil you have in there
Oryo
01-25-2021 08:44 PM
shivaskeeper
01-25-2021 12:33 AM
Hellpmy4ord
11-19-2016 07:19 PM
chesterstroker
6.4L Power Stroke Diesel
01-11-2014 08:33 PM
nagorg
07-18-2010 05:58 PM
Quick Reply: Smoke: diagnostic assistance needed ...
