35's too big
35's too big
I'm looking at buying a 90 Bronco, 4 in susp. lift, with 35x12.5 tires. Problem is that's a bit too big for me, plus it rubs in tight turns. Would going down to 33x10.5 look odd with this lift? If anyone has pics of big Bronco's with a similar lift but smaller tires, that would be great.
35's too big
33 x 12.50's with a 4" lift is a classic look. As was already mentioned, going from 35's to 33's is not going to make your truck any smaller. IF you go with 10.5" wide tires, you won't have your tight steering issue but it will look funny. I think you should keep the 35's and just wear platform heels so you can get in better.
35's too big
10.5" wide tires don't look THAT skinny. Check out the pics in my gallery. I run 33"x10.5" with a 3" body lift. Obviously it is not the same as a suspension lift, but it will give you the same idea of what the 33"x10.5" look like. Plus if you live anywhere that it snows, having those 12.5" wide tires will not help you.
552ford
12-04-2003 10:09 PM
