Fuel Filter Change Interval
Old 03-08-2012, 05:27 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
'94IDITurbo7.3 is offline
how often do you guys change your fuel filter?
thanks
Old 03-08-2012, 05:41 PM
whiteboyslo's Avatar
whiteboyslo
whiteboyslo is offline
20K miles was recommended to me in another thread where I asked the same question.
Mike
Old 03-08-2012, 05:55 PM
'94IDITurbo7.3
thanks
Old 03-08-2012, 06:09 PM
Aune163rd's Avatar
Aune163rd
Aune163rd is offline
I change it with my oil change....
Old 03-08-2012, 06:17 PM
whiteboyslo
What's your interval on oil changes?
Mike
Old 03-08-2012, 06:46 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
Post every 60,000 miles
thanks
the fuel filter should be replaced every 60,000 miles or 48 months.whichever comes first.according to haynes diesel tech book #10300.
according to my 1993 diesel fuel supplement book (thank you ebay!) the chart for change intervals on the fuel filter is also 60k miles.
all other places in the chart have "3" which states:
more frequent intervals may be required dependent on fuel quality and vehicle usage.an instrument panel warning light will glow when servicing is required,or when the ignition key is in the START position.
FYI;
for the interval of draining the water fuel bowl (1993 diesel fuel supplement) has an X checked in all of the mile intervals.which means every 5k miles.it also shares the "3".
so in summary;
change the fuel filter at a MAX 60k miles.sooner if you get the light for that.that one simply reads "fuel filter"
drain the bowl every 5k MAX.sooner if you see the light for that.that one reads "water in fuel"
Old 03-08-2012, 07:05 PM
'94IDITurbo7.3
FYI;
so in summary;
thanks for the good info once again.
Old 03-08-2012, 07:23 PM
FORDF250HDXLT
you betcha.with these fuel filters costing $40-50,there's no point in replacing them needlessly.
Old 03-08-2012, 07:42 PM
'94IDITurbo7.3
were do you get your filters from? i get mine from a-zone. the two that i have used since i got my truck have been fine. not had any problems. cost ~$15.00
Old 03-08-2012, 08:09 PM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
I replace mine once a year, mileage or not.
Old 03-08-2012, 08:23 PM
Aune163rd's Avatar
Aune163rd
Your fuel filters cost 40-50 dollars??!!! I dont know what kind of fuel filter your buying...
Old 03-08-2012, 08:27 PM
Aune163rd's Avatar
Aune163rd
And my oil change intervals are at 3k miles, idc if i am on the side of the road changing my oil, its 3k miles...i keep a full oil change in my IDI's at all times...
Old 03-08-2012, 08:28 PM
Aune163rd's Avatar
Aune163rd
Here is a way for you to save money on these water seperators XD! :
Motorcraft FD3375 - Fuel Filter | O'Reilly Auto Parts
Old 03-08-2012, 08:29 PM
Aune163rd's Avatar
Aune163rd
Old 03-08-2012, 08:39 PM
'94IDITurbo7.3
that is what i have been doing since that is what the PO did. i change it in the fall so it is brand new for the winter months.
Quick Reply: Fuel Filter Change Interval
