Can you help identify my transmission? pics
Old 03-06-2012, 10:20 PM
19fifty4's Avatar
19fifty4
19fifty4 is offline
It's attached to a flathead that came out of a 1950 F1. I think both were original to the truck but don't know for sure. I'm not sure if these numbers show up in the pics but they were cast into the housing.
OIT 7006.
T8D-1. (don't know why it's putting the smiley face - should read T 8 D - 1 with no spaces).
WG 8H.
12 23.
[img]https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=248123&.jpg[/img]
[img]https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=248125&.jpg[/img]
<O:p
[img]https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=248126&.jpg[/img]
Old 03-07-2012, 06:03 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
Looks like a spur gear 4 speed, but doesn't have the separate bell like the ones on my trucks. It has the PTO mounting which I don't think the three speeds had. Somebody correct me if I'm wrong. Stu
Old 03-07-2012, 07:20 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
0IT 7006 / T8D-1 (don't know why it's putting the smiley face - should read T 8 D - 1 with no spaces).
Where is the smilie face? No see um.
When you type 8D together, you get that fracatta smilie face...unless you "disable smilies in text."
After you type a post that has 8D together, scroll down to the bottom of the page, click on the "disable smilies in text" box that I just did.
And, you can edit it out of your post: Click on Edit - then Go Advanced.
Marked: 01T-7006 = Ford part number: 01T-7005 .. Warner T8 4 Speed Transmission Case / 1940/46 Truck / 1941/47 Commercial (1/2 ton) & 122" wheelbase truck.
'Commercial' name changed to F1 in 1948, F100 replaced F1 in 1953.
Old 03-07-2012, 08:56 AM
1952henry's Avatar
1952henry
1952henry is online now
Bill, when did Ford change from the BB prefix on this transmission?
Old 03-07-2012, 01:59 PM
NumberDummy
OP: 01T-7006. This is the ID number marked on and for the case only, it is not the transmission number.
The Ford part number for this case is 01T-7005 / I listed the trans type and its applications, because...I have what long time Ford collectors call The Bible ~ 1928/48 Ford Passenger Car & 1928/47 Truck Parts Catalog.
The Bible sez (on page 293): BB-7006 .. Trans Case = 1932/34 all 4 cylinder.
I'm a long time (since 1956) Ford collector and The Bible is available on a CD from hipoparts.com @ $20.95.
Old 03-07-2012, 02:31 PM
1952henry's Avatar
1952henry
I should have said case, although the insides didn't change much from 32 to the last year this type of transmission was offered, did they?
Old 03-07-2012, 02:39 PM
NumberDummy
I dunno, I suppose I could look all the parts up, but that would take time and it isn't relevant. You can buy your own copy of The Bible on a CD, look 'em up yourself.
My catalog is the original bound paper version with three ring holes. The green covers went bye bye decades ago, it's now inside an original three ring 1953/56 truck parts catalog binder.
The pages are filthy, the catalog stinks like an old greasy garage, cuz it came from a Ford Dealer that opened in 1918, closed in 2008.
Originally Fortner Ford, then Fortner & Loud Ford, then Loud Ford, then Pasadena Ford. Now Hertz Car Sales is located on the property...2047 E. Colorado Blvd., Pasadena CA
Old 03-09-2012, 10:21 PM
19fifty4's Avatar
19fifty4
19fifty4 is offline
Bear with me here as I try to follow along. My shop manual begins with the 49 model year so I'm not sure it has the answer anyway.
The transmission referenced above was native to the 40-46 truck and 41-47 commercial and wasn't offered on the 48-52 F1's? Is that correct? If so, either it was not originally mated to the flathead I have or I have an earlier version flathead (40-47) than I first thought?
Old 03-10-2012, 12:00 AM
NumberDummy
The transmission case referenced above was native to the 40-46 truck and 41-47 commercial and wasn't offered on the 48-52 F1's? Is that correct?
Correct.
Where is the dizzy, mounted low at the front of the engine between the waterpumps, or sticking up out of the right (passenger) side of the engine?
Old 03-10-2012, 09:27 AM
19fifty4's Avatar
19fifty4
19fifty4 is offline
I'm thinking this is the latter / sticking up out of the engine - pass side. Correct me if that's not right.
Old 03-10-2012, 10:06 AM
NumberDummy
Latter is correctamundo. You didn't edit your post to get rid of that 8D smilie face. See post 3 for how to get rid of it.
Old 03-10-2012, 10:33 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
19Fifty4, your trans is an earlier version of the trans that would have been original to your truck. Someone has undoubtedly replaced the original with one from a junkyard. The primary difference is the integral half-bellhousing vs the separate half-bell (hogshead) that 48-52 used.
Old 03-10-2012, 11:16 AM
19fifty4's Avatar
19fifty4
19fifty4 is offline
Thanks. I think I edited out the smiley face.
So does that make the tranny assembly longer since it's 2 pieces or is it basically the same length, just 2 pieces instead of 1? Will that affect the how the linkage lines up between the pedal and the bellhousing? Where the tranny hits the crossmember? How about the position of the where the shifter comes thru the floor?
Old 03-10-2012, 12:50 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I wouldn't think anything will be different, but some quick measurements will confirm. Check the rear mount on the trans, is it correct for your frame?
abe
167
01-04-2023 10:50 AM
filthy6
43
11-07-2015 07:49 PM
sunbird79
28
03-04-2012 11:05 PM
03 Power Smoke
01-29-2008 09:58 PM
fordboy_52
Kansas Chapter
07-07-2007 10:06 AM
Quick Reply: Can you help identify my transmission? pics
