Hole in transmission case?
Old 03-04-2012, 01:03 PM
JaySVX's Avatar
JaySVX
JaySVX is offline
After driving, i smelled something horrible burning. When I get home, I get on my creeper and roll under to look for anything suspicious, and I find this. It is not where the drain plug in the pan is, it's in front of that. I checked the temp when I was driving but it never got high. It would greatly appreciate any information, I really need my transmission to not explode on me right now, I have a lot of driving to do.
Here's a gallery where there are some pictures, Hopefully someone can tell me what is the problem. It looks like there were threads, and some are left, but it looks like most are gone.
Photo Album - Imgur
Old 03-04-2012, 01:10 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
Hows the fluid leval??
how does the fluid smell??
IDK what went there In that area is where the Torq converter is so I dont think even with the hole you would have lost fluid there
Old 03-04-2012, 03:54 PM
JaySVX's Avatar
JaySVX
JaySVX is offline
Fluid levels are all full, no burnt smell. only ever smell burning when i am highway driving, then stop. i checked all brake lines and rotors and pads, nothing out of the ordinary. it doesn't smell like burnt fluid, more like plastic, very strong. but if i drive around town it's fine. it points to the torque converter but when i shoved my nose into that little hole, i did not smell anything.
Old 03-04-2012, 05:28 PM
raptor131's Avatar
raptor131
raptor131 is offline
Maybe she cleans it good.
Old 03-04-2012, 05:51 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
Wow, what caused that hole? Almost looks threaded. I had to go crawl under my truck to see. Weird.
Old 03-04-2012, 06:10 PM
JaySVX's Avatar
JaySVX
JaySVX is offline
The uppper part is threaded, the lower part is not. Looks like there was a plug in there, but it came half out, then "blew out' or got knocked out, pulling the other threads clean. Can anyone check and tell me if they have it?
Old 03-04-2012, 06:27 PM
amdriven2liv
I do not have that in my tranny case. Should have said that from the git-go.
Old 03-04-2012, 06:48 PM
BLADE35's Avatar
BLADE35
Nothing like that in mine either just went and look curiosity was getting me no hole bolt just NOTHING in that circle indent
it shouldnt hurt nothing just the TC in there
Old 03-04-2012, 06:49 PM
Unrealo4's Avatar
Unrealo4
Unrealo4 is offline
Isn't that a inspection point on the transmission? I thought you could knock it out then plug it after the inspection. Of course I could be wrong.
Old 03-04-2012, 08:21 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Whatever the reason the hole is there, I can tell it's not supposed to be that way from the factory. Someone, at some point, drilled that hole there for whatever purpose, I couldn't tell you. The only thing that comes to mind, is for access to the torque converter to drain fluid. From the factory, there is no drain plug on the torque coverter, but that doesn't preclude the possibility that someone might have drilled and tapped a plug into it, for access to draining it when needed. Although, that hole does look awfully small for that purpose even.
Old 03-04-2012, 10:25 PM
amdriven2liv
Might a person be able to "spin" the torque converter, and see if there is an "after market" drain put in?
Old 03-04-2012, 10:32 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
That actually would have been my next question to the OP.
Old 03-05-2012, 07:52 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
Yes you can. Put a socket and breaker bar on the front crank sprocket and you can turn the engine. I do it from underneath so I can watch the converter. Leave the trans in park while doing this.
Old 03-06-2012, 06:16 AM
JaySVX's Avatar
JaySVX
JaySVX is offline
How do you reach the front crank sprocket and be able to see the torque converter?
Even if I can look up the little hole, what am I looking for?
Old 03-06-2012, 06:26 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
You won't see much in that hole. I'm wondering if someone drilled it to allow oil to drain from the rear main--LOL. My tranny housing has about a 2 1/2 or 3" hole drilled out for converter bolt access. I was told there is a replacement plug available for it but I've never installed anything there for the past 120K miles and had no issues.
Quick Reply: Hole in transmission case?
