Heidts Super Ride II control arm bushing wear
I've got about 5 years and 3500 miles on the 55 since installing the Super Ride II front end. Lower and upper control arm rubber bushings are deteriorating and falling out. I noticed the bottom's 1st and thought the cause may have been oil saturation because of front crank seal leak, but the uppers are bad also, with no oil present on them.
Anyone else have that issue? Is there an alternative bushing that will work. If not, maybe I should modify to take steel heim joints?
Not the vendor that you mention specifically, but IMO much of the rubber coming from across the oceans is inferior. Every tractor tire inner tube I put on my Jubilee restoration had a slow leak, were porous. Various imported hoses and lines appear to be showing early deterioration. Remember the warning about Chinese valve stems. I had about ten bad ones.
You could use Urethane bushings, but get the softest ones you can find. DON'T use heim ends they will jar your teeth out and beat themselves to death very quickly, those pivots need some resiliency to absorb road shocks. Best: Heidts should be able to tell you the "donor" source for those bushings, then buy high quality replacements like Moog or OEM.
5 years isn't an unusual lifespan for rubber parts, especially given your local.
jniolon
08-26-2015 07:56 PM
twallace
09-15-2004 03:10 PM
