Vacuum and Electrical questions
Hey guys,
A couple questions. I was digging Around under the dash and trying to reconnect things. The vacuum gauge runs to a t connector in one of the pictures. I disconnected the hose and there is little to no pressure.
Neither of the temperature gauges work and they are plugged in. How would I troubleshoot this?
Also should the battery gauge always be connected? Or should it just be powered when the ignition is on?
There is a wire taped up that doesn't go anywhere near the distributor in one of the pictures, can anybody figure out what it is?
Hey guys,
Vacuum.... These things didn't come with vacuum gauges so it's an aftermarket, right? It's not supposed to have positive pressure but rather negative pressure (vacuum). Suck on the hose and does it make the vacuum gauge move? Where is the other side of the tee connected to??? Is it even connected to anything?
Temp gauges... it is getting power? Ground the signal lead supposedly feeding the signal and the gauge should peg out.
Wire? We don't see a wire that its taped up. Please post the wire & trace color.
Ammeter... works only when ignition is on. Sometimes it doesn't appear to move so I don't trust them the least. In fact, I totally ignore it if it's not "normal" and it least doesn't give me a bad reading.
Part of owning/operating these rigs is being a sleuth about it. Post questions only until you've at least done some homework which can help us help you. Your question leads me to believe FTE was your first stop when it really shouldn't be. 'Not busting your nards.. just trying to help you understand how to best go about getting help.
Resource:
Wiring Diagrams:http://www.fordification.com/tech/schematics_h.htm
Ford Truck Technical Drawings and Schematics - Section I - Electrical and Wiring
Totally forgot to attach the pictures! Vacuum + Electrical - Imgur
Then the aftermarket ammeter must have been wired incorrectly. I will have to redo that.
I have been digging around about the vacuum but am not sure what to call the hose that it is connected to. It comes off the carb but haven't been able to research more.
Most of the wires seem to have been replaced so I'm just trying to decipher what is what. I can't always tell what is original.
I normally just come here after running out of swear words and hit dead ends. I'm sure as I learn more I will last longer and longer without coming here.
Thanks again!
Thanks again!
I'm back on this. I've been reading around and I think I understand how the automatic choke works. (The air creating a vacuum/closing the choke, etc.) but I am confused on the parts. I circled the 2 parts that I think have to do with it.
The part circled in red is the vacuum plunger that either opens or closes it? And the part circled in green does the opposite? Am I on the right track?
Also that t connector is the one that connects to the vacuum gauge, so I assume that is incorrect because I never get a reading even thought I know the vacuum gauge is working.
-Aidan
-Aidan
Got some more pictures.
Here is the passenger side:
There is supposed to be a spring inside that plastic black part correct? Does the spring push the choke closed, and then the vacuum cylinder pulls it open?
Here is the drivers side:
I'm a little confused because that side also looks like it could have a choke pull-off.
Also I'm still confused on why the vacuum gauge taps into that hose on the carb. Should it be tapping into the larger black hose in this picture?
Thanks!
Thanks!
The part you circled in green is a choke pull off.
There is no spring in that black cap because that is an aftermarket manual choke add-on. That carb originally was an automatic choke that had the spring. The vacuum line should be hooked up directly to a vacuum manifold that's screwed into the intake manifold. There will be one if you have automatic trans or power brakes.
jeffreyclay
07-03-2019 07:00 PM
82Frankenstein
07-14-2018 11:09 AM
Granpa's76
09-06-2013 09:09 PM
86f2504x2
11-20-2011 03:53 AM
