95 f350 wont pull fault codes
I can't seem to pull fault codes even though it says there are 124 of them.
Throttle position sensor registers 68.6% at any engine speed. I have replaced MAP sensor, cam position sensor and speed sensor and still get CEL, along with very harsh up and down shifts. When CEL light off the vehicle surges and will quit running at low speeds, at higher speeds it will stumble until CEL comes on and will run fine except the shifting problem. also coolant temp registered 276 deg. but the engine was only running for 2-3 minutes at that time.
If anyone has any ideas what is the cause of this before I buy any more sensors I would appreciate it.
96ford4x4turbodiesel
06-02-2004 06:32 AM
